NetBSD binary pkgsrc-current for Pinebook
if interested Im building pkgsrc-current packages for the arm64 Pinebook, you can check the progress here - http://45.76.81.249/pkgsrc/pinebook/netbsd-aarch64/All/
I post progress updates on my twitter here https://twitter.com/astr0baby
Some cool games compiled for the Pinebook
- Exult (Ultima VII)
- Pentagram (Ultima VIII)
- freesynd (Syndicate)
- Ur-Quan Masters (Starcontrol2)
- Scummvm 2.0
- Doom
- Quake 1, 2
- FreeCiv
I have been watching your tweets and videos a few days now - good fun.
Stickied the thread.
(11-23-2018, 04:51 AM)Luke Wrote: I have been watching your tweets and videos a few days now - good fun.
I will be adding more packages as I build them.
Thanks, you have generated big buzz on BSD community. Smile
I'm working on same way....
arm64# pkg_info -X zonetab-0.tgz
PKGNAME=zonetab-0
COMMENT=NetBSD zone.tab file
SIZE_PKG=18582
BUILD_DATE=2018-12-04 18:04:33 +0000
CATEGORIES=time
LICENSE=
MACHINE_ARCH=aarch64
OPSYS=NetBSD
OS_VERSION=8.99.26
PKGPATH=time/zonetab
PKGTOOLS_VERSION=20091115
FILE_NAME=zonetab-0.tgz
FILE_SIZE=12350
DESCRIPTION=This package installs a zone.tab file (part of the tzdata distribution)
DESCRIPTION=which is commonly installed with the OS but missing in NetBSD.
arm64# pkg_info -X http://45.76.81.249/pkgsrc/pinebook/netb...etab-0.tgz
PKGNAME=zonetab-0
SIZE_PKG=18582
BUILD_DATE=2018-12-03 11:51:49 +0100
CATEGORIES=time
LICENSE=
OPSYS=NetBSD
OS_VERSION=8.99.25
Well, after using NetBSD on my pinebook I see it's very unusable for stable/standard purposes, so I decide to continue with manjaro arm instead NetBSD.
If you want I can upload/send you my /usr/pkgsrc/packages/all. It's about 650 MB of data. Send me where and how to do that on a private message.
(12-12-2018, 05:17 AM)erchache2000 Wrote: Well, after using NetBSD on my pinebook I see it's very unusable for stable/standard purposes, so I decide to continue with manjaro arm instead NetBSD.
Why do you say its unusable ? Can you define what exactly is your "standard purposes" usage Smile
Create an usable system takes a lot of time to compile it... ;(
(12-17-2018, 03:41 AM)erchache2000 Wrote: Create an usable system takes a lot of time to compile it... ;(
My Pinebook NetBSD aarch64 is working nonstop since about 17th November 2018 on NetBSD pkgsrc -current binary packages to make this task a little easier for others... what is amazing is that this machine needs little power, is quiet, does not heat-up .. just works. things just take time ...
Currently Im building QT5 NetBSD -current packages on the Pinebook ( it has been put to work non-stop for a month now)
If you want to see some NetBSD related benchmarks with ffmpeg I have done please check it here
https://astr0baby.wordpress.com/2018/12/09/pinebook-netbsd-arm64-current-multimedia-benchmark/
  NetBSD will does not install to eMMC ronverbs 3 11,997 06-24-2020, 01:07 AM
  NetBSD images for the pine (and other boards) e-minguez 9 21,297 08-20-2019, 02:56 AM
Last Post: e-minguez
