NetBSD will does not install to eMMC
I downloaded the NetBSD Pinebook image from invisible.ca (https://www.invisible.ca/arm/) and created a microSD card, as directed using Etcher. My Pinebook (1080p) booted, but when I dd'd the image to /dev/rdl2c I got a ton of errors. Now my Pinebook does not boot, unless there is a SD card inserted.
arm64# dd if=NetBSD-evbarm-aarch64-201905120950Z-pinebook.img of=/dev/rld2c bs=1m conv=sync
    dd: /dev/rld2c: Input/output error
    30+0 records in
    29+0 records out
    30408704 bytes transferred in 11.143 secs (2728951 bytes/sec)
This generated a ton of "ld2c: error writing fsbn..." errors. When I reboot I get a blank screen.
My disklabel looks like this:
arm64# disklabel ld2
    # /dev/rld2:
    type: ld
    disk: ld2
    label: default label
    flags:
    bytes/sector: 512
    sectors/track: 63
    tracks/cylinder: 32
    sectors/cylinder: 2016
    cylinders: 1040
    total sectors: 2097152
    rpm: 3600
    interleave: 1
    trackskew: 0
    cylinderskew: 0
    headswitch: 0           # microseconds
    track-to-track seek: 0  # microseconds
    drivedata: 0
    5 partitions:
    #        size    offset     fstype [fsize bsize cpg/sgs]
     c:   2097152         0     4.2BSD      0     0     0  # (Cyl.      0 -   1040*)
     e:    163840     32768      MSDOS                     # (Cyl.     16*-     97*)
    disklabel: boot block size 0
    disklabel: super block size 0
    disklabel: partitions c and e overlap
Any ideas on how to get NetBSD running on my brand new Pinebook?
[url=http://www.invisible.ca/][/url]
(05-14-2019, 02:53 PM)ronverbs Wrote: I downloaded the NetBSD Pinebook image from invisible.ca (https://www.invisible.ca/arm/) and created a microSD card, as directed using Etcher. My Pinebook (1080p) booted, but when I dd'd the image to /dev/rdl2c I got a ton of errors. Now my Pinebook does not boot, unless there is a SD card inserted.
    30+0 records in
    29+0 records out
The bs=1M sounds excessive... depending on the hardware, there are limitations on the block size the kernel will handle.
Oh, and leave out the conv=sync? The man page says "Pad every input block to the input buffer size." - you don't want that.
Maybe re-try with something like
dd if=NetBSD-evbarm-aarch64-201905120950Z-pinebook.img of=/dev/rld2c bs=32k
    30+0 records in
    29+0 records out
Thank you for your response. I did try that and got the same response, that is dd errors and a blank screen upon rebooting. For now I may stick with KDE Neon. At least that works. Sad though, I am such a NetBSD fan boy.
I don't know why the error (it looks like you're writing beyond the end of the partition). But 1m does not sound excessive to me, I tend to use 8m.
And maybe I'm missing something but I think you want to write to /dev/rld2 rather than /dev/rld2c no?
  Install OpenBSD 7.2 on Pine64+ (2Gb) pierrep 2 16,247 03-29-2023, 04:34 PM
Last Post: tpaul
  NetBSD images for the pine (and other boards) e-minguez 9 21,248 08-20-2019, 02:56 AM
Last Post: e-minguez
  NetBSD binary pkgsrc-current for Pinebook astr0baby 16 34,991 05-24-2019, 11:58 AM
Last Post: Luke
