12-16-2017, 04:45 PM
http://synfare.com/599N105E/hwdocs/rock64/index.html
Here is a link to the layout of the gpio pins on the rock64. If you look at the pi2 bus, pins 2 and 4 are labeled 5V input. Is this a viable option to power the board? I do not want to use the barrel jack because I am putting this board in a larger system that I already have a large 5V power supply for. If it is, do I connect the +5V to the 5V pin and the -5V to any ground pin?
