PoE Splitter that's compatible with the ROCK64?
Looking to replace my Pine A64 with a more powerful ROCK 64 4GB, but I need PoE power for my use case.  I understand the requirement for power is a 5V adapter with up to 3A current.
So there are a few PoE Splitters out there, such as this one (http://www.poesystem.com/15.4w-poe-splitter/693.html) which can output 15.4W (5V/3A), but the specs tell me it's rated at 10/100Mbps, and has a 5.5mm barrel jack.  I'd have to get an adapter to drop to 3.5mm, but it's not worth it unless it can handle GbE speeds (or at least near).
Is there any known splitters out there that anyone could recommend?  Would save me time and potentially buying something that doesn't work.
Thanks!
(09-07-2017, 10:28 AM)tycoonbob Wrote: Looking to replace my Pine A64 with a more powerful ROCK 64 4GB, but I need PoE power for my use case.  I understand the requirement for power is a 5V adapter with up to 3A current.
Thanks!
Here is the PoE splitter for ROCK64 carry at PINE64 store: https://www.pine64.org/?product=rock64-poe-splitter
(09-07-2017, 12:25 PM)tllim Wrote: Here is the PoE splitter for ROCK64 carry at PINE64 store: https://www.pine64.org/?product=rock64-poe-splitter
Holy crap...how did I miss that?? Ugh, any way I can add one to an existing order so I don't have to pay separate shipping?
You could try emailing sales@pine64.org - you may be lucky and get though to them before the order goes out.
Can someone please confirm if this PoE splitter in the store is capable of gigabit speeds? I've noticed a lot of the cheaper ones out there are only 10/100M. Thanks!
  Are HW design files available for ROCK64? irenek 3 5,119 12-11-2023, 09:31 PM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 0 360 11-23-2023, 05:05 AM
Last Post: ReleaseTheGeese
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 1,111 04-26-2023, 11:38 PM
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 0 645 03-21-2023, 03:48 PM
Last Post: o1CRiMSON1o
Question Compatible eMMC modules and benchmarks danboid 7 14,671 03-09-2023, 08:14 AM
Last Post: arvendui
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 13,383 01-15-2023, 10:36 AM
Last Post: ds00
  rock64 totally brick dakobg 2 1,799 11-07-2022, 05:45 PM
Last Post: olivercfc
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 3,570 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 2,678 06-08-2022, 12:44 AM
Last Post: Zoz
Smile wooden case for ROCK64 killor 13 16,749 03-04-2022, 06:56 AM
Last Post: killor
