Rock64 has not Ethernet LAN
Sad
I just flash android OS in rock64 anh complete. I have tried many time to connect to Ethernet but it can not, I realy don't know how to setting the internet for rock64 4GB ram. Please help me to solve this problem. Thanks a lot
The Ethernet connection should just work. Is there anything unusual about your setup?
hi, meet us on irc (see address below) and we'll help you live.
Hi MarkHaysHarris777
I don't know how to connect to IRC,
(08-18-2017, 09:40 AM)fire219 Wrote: The Ethernet connection should just work. Is there anything unusual about your setup?
I complete flash Android and then connect LAN wire for ethernet, but nothing happen, I cannot ad my Google account and didn't do anything in internet. I cannot find the ethernet setting also.
(08-18-2017, 10:44 AM)MarkHaysHarris777 Wrote: hi,  meet us on irc (see address below) and we'll help you live.
I have flash Android 5 times on Rock64, but It still has not Ethernet. It didn't see the IP address.
(08-20-2017, 02:47 PM)Luke Wrote: Just to confirm - something must have changed from pre-production board (where I am getting networking to work just fine) to production board, where I too cannot connect to my lan or the internet. No activity on the LEDs. I already pointed it out to ayufan in the chat. As a side note, I think its tied to the issue with 2 eth connections appearing in Linux (something not present on pre-pro unit).
Actually lukasz, its the other way round.  The two eth0 & eth1 are showing up on the new build 0.4.16 on the pre pro unit !!   ... and not the production board.
My production board xenial-minimal 0.4.16 had one eth0;   my pre pro unit has two eth0 & eth1;  both with the same mac addy ( addy bug ) but the eth1 is clearly the internal 10|100 PHY.  The eth0 is the Gbe PHY .
( just for the record )
Correct, I forgot to cross out or delete what I wrote before I went to bed - will do so now.
However, the networking chip has changed since pre-production units. Networking works for Thomas in IRC on a 4Gb production board but it doesn't work on my, presumably identical to his, 4Gb production board.
oh, what a nightmare.
When they make changes like that they need to notify the community;
Newest release should solve the GbE Ethernet issue.
edit: it does not.
  Android Images (ROCK64) pineadmin 76 170,020 05-13-2024, 04:13 PM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 5,418 08-04-2021, 07:35 PM
Last Post: Rocklobster
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 4,085 03-12-2021, 01:38 PM
Last Post: Wizzard
  Android on Rock64 SD Problem ElBoluTony 3 6,123 10-07-2020, 12:10 PM
Last Post: ElBoluTony
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 4,803 09-18-2020, 07:58 PM
Last Post: BowerR64
  Can't boot android 9 on rock64 maks2204 5 8,939 09-09-2020, 08:44 AM
Last Post: BowerR64
Question Regular Android build for Rock64? fender90 18 26,720 09-09-2020, 08:04 AM
Last Post: BowerR64
  Minimum requirements for ROCK64 Android install? eugenev13 0 2,774 06-04-2020, 02:23 AM
Last Post: eugenev13
  Android 10 for Rock64? Blinky 0 3,737 04-21-2020, 12:55 AM
Last Post: Blinky
  port Rock64 to Lineage OS? noob 10 19,525 04-11-2020, 04:00 PM
Last Post: Pepe
