The internal speaker stops working
Exclamation
Hello
The internal speaker no longer works on my Pinephone, even after rebooting. I haven't updated it for several days. I assume that I broke something after trying to use an external speaker through bluetooth. The internal earpiece and the headset still work.
How can I solve my problem, preferably without reinstalling the whole system as I use my phone daily?
(01-15-2024, 02:56 AM)anonymous Wrote: Hello
I'd a similar Problem on Mobian Trixie some weeks ago.
Go to "SETTINGS > AUDIO or SOUND:
Chose the very first Input and set it to "Internal speaker"
Chose the second Input and set it to "Make a phone call"
HTH
Ciao
Walter
HTH
Ciao
Walter
Thank you. I used a similar workaround a while ago when switching to Pipewire but my current problem is different, I still have no sound.
May be I am wrong but I think the only solution is to repair. Buy a new speaker or to check the connection.
I did not that yet although one if my pinephones also has the speaker totally silent.
Have luck.
Have luck.
Actually, there seems to be a error message indicated by dmesg that mentions a problem with bluetooth:
Bluetooth: hci0: broken local ext features page 2
I would like to determine whether it's an hardware or software problem once for all.
When I test the sound in Gnome settings, the gauge shows some blue rectangles when using the internal speaker.
As a workaround for the alarm, I use the jack plug with an external speaker.
Have luck.
Just use factory test build to check out whether is hardware issue. Here is the link: https://wiki.pine64.org/wiki/PinePhone_S...test_build
walter1950 mentioned Trixie. Actually, switching from Bookworm to Trixie fixed this bug. Thank you for your help.
  Mobile internet via cellular network mostly not working Anna 18 10,565 01-19-2024, 02:59 AM
Last Post: anonymous
  APN settings not working with new operator SIM card user641 1 1,065 03-01-2023, 04:43 PM
  Possible Solution for Microphone Not Working Ferriah 0 973 02-13-2023, 01:09 PM
Last Post: Ferriah
  Squeekboard stopped working Zebulon Walton 2 1,221 11-24-2022, 08:41 PM
  suspend inhibit no longer working jsch 3 2,043 10-23-2022, 09:20 AM
Last Post: LibrePhoneUser
  Rescue Your Mobian post Update Aug22 faster fix to working guide biketool 9 4,885 09-05-2022, 12:10 AM
  How to get Pinetime working with Pinephone arkadione 12 7,528 08-28-2022, 12:30 PM
Last Post: Fish
  Receiving SMS stopped working treebeard 11 5,689 08-12-2022, 10:31 AM
Last Post: treebeard
  PP keyboard not working at all jojuma 3 1,834 08-03-2022, 10:02 AM
Last Post: jojuma
  Calls 4G not working oliwierzgorniak 1 1,337 07-04-2022, 05:15 AM
Last Post: zetabeta
