PineTab2, Ubuntu Touch and WiFI
Sorry if this has already been asked. I put Ubuntu Touch on an SD card and booted successfully. I enabled WiFi but it did not see my network. I manually added hidden network info with no luck. I am using the same wifi adapter setup I use with the stock OS which works well. If I need to direct this to UB Ports I will.
Oddly enough if boots from the SD card without using the UART adapter I purchased because my PT2 did not come with one. Purchased off eBay so original owner may have not seen it and accidentally discarded it.
Wifi driver is not ready, there's several posts on the forum about this.
Unless you are using a working adapter and then it's a different kind of problem, have a search and you will see status and workarounds
(01-01-2024, 07:14 AM)Corconegre Wrote: Wifi driver is not ready, there's several posts on the forum about this.
Appreciate the reply. I am on the UBports forums as well so I am watching the Wifi driver release with enthusiasm for the factory install as well as Ubuntu Touch development.
  Progress on Wifi Chip frtodd 0 231 05-01-2024, 10:25 AM
Last Post: frtodd
  Pinetab2 not starting Corconegre 6 1,710 03-18-2024, 10:47 AM
Last Post: zogkarndon
  Pinetab2 Audio Hiss/Static from speakers scottgr 2 464 03-16-2024, 11:56 AM
Last Post: scottgr
  wifi with caveats frtodd 3 935 02-15-2024, 09:22 AM
Last Post: dachalife
  pinetab2 hardware is not very good lmartin 11 2,454 01-13-2024, 03:45 AM
Last Post: Darth-Apple
Information nvme ssd and open pinetab2 snock 0 236 01-12-2024, 06:37 PM
Last Post: snock
  Pinetab2 screen removal Corconegre 5 1,424 01-10-2024, 08:08 AM
Last Post: stozi
  Using the Pinetab2's PCIe slot FortunateFowl 0 364 12-22-2023, 01:23 PM
Last Post: FortunateFowl
Exclamation Pinetab2 Keyboard Issues lockedpotato 0 546 10-14-2023, 05:48 PM
Last Post: lockedpotato
  pinetab2 booting when adapter connected Ome Ko 16 3,088 09-15-2023, 11:45 PM
Last Post: Ome Ko
