SMS not delivered if receiver offline at sending time
Yes that's normal, the validity period seems to be something like 2h.
PinePhone Beta Edition 3GB RAM - custom firmware v.0.7.4 - ADSP v.30.007 - postmarketOS edge - sxmo
(08-29-2023, 04:51 PM)alpineduck Wrote: Yes that's normal, the validity period seems to be something like 2h.
Yes now I see it. Thanks for your work! This is actually quite big bug if you think how people expect phone to work.
I cannot comment in the upstream bug report because I have no account on puri.sm, but I think I found the place with the issue:
https://source.puri.sm/Librem5/chatty/-/...nt.c#L1454
This is setting the validity period to 168 something. (The unit is not documented.) Since you found it to be around 2 hours, I guess the unit is minutes.
Please forward this information upstream, I think they should be able to fix the issue quickly with the line pinpointed like that.
I think it should be safe to just delete or comment out that line. As far as I can tell, Spacebar just leaves the timeout at the default, and ModemManager then does the right thing.
i can confirm this issue, and validity time is somewhere in 2 hours. tested on pinephone to pinephone.
The validity time is exactly 2 hours and 50 minutes. 168 minutes = 2 hours 48 minutes, but it gets rounded up to the next higher timeout supported by the GSM standard, which is 2 hours 50 minutes (timeouts less than 12 hours have 5 minute granularity).
  Complete noob to the Pinephone 64, cannot set time and date. gordr 11 2,983 06-06-2023, 10:27 AM
Last Post: gordr
  MMS sending stopped working amindfv 2 1,315 01-16-2023, 09:44 PM
Last Post: treebeard
Question How long does the phone need to be chrarged prior to turning on the 1st time? awsdert 2 2,750 04-30-2021, 01:40 PM
Last Post: awsdert
  What is the first-time password? Chupacabra 10 12,698 03-29-2021, 09:43 AM
Last Post: Puro Antinori
  Delivery Time? mlnease 16 15,869 11-17-2020, 12:46 AM
Last Post: ryo
  First Time Password 123456 does not work (SOLVED) OggieDoggie 0 1,760 11-06-2020, 09:14 PM
Last Post: OggieDoggie
  First time user really confused - need a how-to binkyd 8 10,132 07-21-2020, 04:21 PM
Last Post: bcnaz
  Date and Time changes to august 2115 rakor 11 11,110 07-13-2020, 04:17 PM
Last Post: bcnaz
  Pinephone, not delivered yet ?? -- UK Lin12 15 14,360 04-16-2020, 11:06 AM
Last Post: C3lt
  Your lies cost me time and money hmmmmm 16 19,613 02-22-2020, 10:49 AM
Last Post: aaspectre
