SMS not delivered if receiver offline at sending time
I've been using the PinePhone regularly for about half a year. Calls and SMS have been reliable, with the notable exception of the following problem that I would like to understand, and hopefully solve:
If I send a SMS to a phone that's offline, the expected behaviour of any SMS service is that the message is temporarily stored by the carrier, and when the receiver phone is later brought online, it gets the message delivered. For some reason, this isn't the case for the messages I send from the PinePhone. Messages are delivered properly when the receiver is online, but they never reach their destination if it was offline at the time of sending.
I tried with two different carriers and both 3G and 4G networks for each: the problem is systematic with the PinePhone, while messages are delivered properly when the same SIM card is used in another phone. The problem also persisted across various upgrades of the modem firmware, including ADSP.
When logged in to my user account on my carrier's website, I can see that the messages were successfully sent.
To me, this looks like the PinePhone sends its messages together with some kind of metadata meaning "do not attempt later delivery, instead discard the message if the receiver is unreachable". Could anyone confirm this? Can it be changed and how? I couldn't find any information on that matter and to be honest I'm quite surprised to be the first one to bring this up.
PinePhone Beta Edition 3GB RAM - custom firmware v.0.7.4 - ADSP v.30.007 - postmarketOS edge - sxmo
(05-03-2023, 05:48 PM)alpineduck Wrote: Hello,
I would strongly suggest you to open a bug report in the corresponding places (modemmanager, biktorgj's custom firmware or similar). This is essential to have discussions about issues being addressed in the right place and centrally collected, in contrast to distributing discussions to various social media platforms, including this forum. Even if the bug would only affect you there is no reason to not open a bug report.
I investigated further and found out that the SMS validity period which you can manually set when sending a message from nmcli is not respected, so I reported the issue to ModemManager developers: https://gitlab.freedesktop.org/mobile-br...issues/737
(05-23-2023, 08:28 AM)alpineduck Wrote: I investigated further and found out that the SMS validity period which you can manually set when sending a message from nmcli is not respected, so I reported the issue to ModemManager developers: https://gitlab.freedesktop.org/mobile-br...issues/737
This works in my Pinephones just like it should.
SMS or MMS is stored by carrier and when modem boots it will fetch the message and receives it.
Can you check do you see the messages when you use
mmcli -m any --messaging-list-sms
I don't have any problem with receiving messages on the PinePhone, this works as intended. The issue affects messages sent from the PinePhone to any other phones, when these are offline.
(05-27-2023, 08:07 AM)alpineduck Wrote: I don't have any problem with receiving messages on the PinePhone, this works as intended. The issue affects messages sent from the PinePhone to any other phones, when these are offline.
Sorry I wrote it badly.
I shutdown my Pinephone and lets call it PP1.
I have also another Pinephone lets call it PP2.
I will send SMS from PP2 to PP1 while PP1 is powered down.
I boot my PP1 and when modem comes alive it will receive the SMS which was send when the device was offline.
It also works for me if the receiver is connected to the network in the following minutes, but it doesn't if it's hours later. I didn't make tests of intermediate durations to tell what actual validity period is being used. Possibly 5 minutes if the default value for TP-VP is 0 (https://en.wikipedia.org/wiki/GSM_03.40#Relative_format).
Update on this issue:
Contrary to my expectations, it seems to be a Phosh/Chatty bug.
I thought it was a more general problem because the tests I made using mmcli on the command line weren't successful either, but I may not have set the proper command line options, or mmcli may use options set by Chatty, I didn't take time to investigate this yet.
Anyway, I did tests with sxmo and Plasma Mobile, and both successfully delivered my messages on the following day, while Chatty (on either Phosh or Gnome Mobile) didn't.
I'm waiting for my account to be validated in order to be able to report a bug on https://source.puri.sm/Librem5/chatty...
Issue opened: https://source.puri.sm/Librem5/chatty/-/issues/831
I just tried and after 30 minutes I did receive the sms as usual.
Postmarket OS edge with latest updates
OG PP Beta edition
BIktorjgs 0.72 firmware with 03 something ADSP
  Complete noob to the Pinephone 64, cannot set time and date. gordr 11 2,983 06-06-2023, 10:27 AM
Last Post: gordr
  MMS sending stopped working amindfv 2 1,315 01-16-2023, 09:44 PM
Last Post: treebeard
Question How long does the phone need to be chrarged prior to turning on the 1st time? awsdert 2 2,750 04-30-2021, 01:40 PM
Last Post: awsdert
  What is the first-time password? Chupacabra 10 12,698 03-29-2021, 09:43 AM
Last Post: Puro Antinori
  Delivery Time? mlnease 16 15,869 11-17-2020, 12:46 AM
Last Post: ryo
  First Time Password 123456 does not work (SOLVED) OggieDoggie 0 1,760 11-06-2020, 09:14 PM
Last Post: OggieDoggie
  First time user really confused - need a how-to binkyd 8 10,132 07-21-2020, 04:21 PM
Last Post: bcnaz
  Date and Time changes to august 2115 rakor 11 11,110 07-13-2020, 04:17 PM
Last Post: bcnaz
  Pinephone, not delivered yet ?? -- UK Lin12 15 14,360 04-16-2020, 11:06 AM
Last Post: C3lt
  Your lies cost me time and money hmmmmm 16 19,613 02-22-2020, 10:49 AM
Last Post: aaspectre
