Pinephone Pro Convergence Dock Ethernet performance with non-pro pinephone
(03-06-2023, 01:29 PM)Matt2020 Wrote: Thanks @emsyr .  That was a good idea.
I tested my _old_ dock with my mbp, and it also gets around ~100Mb/s (much better than 5).
The issue now is whether the problem is software or the USB port on the pinephone.
If it is hardware, then that is that.  I'm not buying the Pro version just to get around that.
If it is software, maybe I just need a different distribution?  I guess I could try booting the multi-boot and trying them all out.
Anyway, thanks for your help!
You're welcome, I'm glad I somehow helped!
I very often get help from the community, it's a pleasure when I sometimes have the chance to give something back...
  Case for Pinephone totilele 13 7,310 04-11-2024, 11:48 AM
Last Post: gramonyl
  PinePhone Dock with laptop? Mikey1977Y2J 2 645 12-12-2023, 05:43 PM
Last Post: Mikey1977Y2J
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,211 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 457 10-22-2023, 03:39 PM
Last Post: rotwang
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 525 10-21-2023, 07:50 AM
  Use the Linux Console with the PinePhone Keyboard mburns 2 1,029 10-20-2023, 04:11 PM
Last Post: mburns
  Convergence package USB-C Docking Bar for Wired Ethernet (part II) Peter Gamma 4 975 10-08-2023, 11:49 PM
Last Post: zetabeta
  Mouse for the PinePhone? Peter Gamma 21 15,464 10-04-2023, 10:24 AM
  PinePhone Wallet Case Shane 5 5,056 09-17-2023, 12:52 PM
Last Post: J T
  KB: Using bus powered USB peripherals with the pinephone keyboard mounted docsunset 9 37,572 08-07-2023, 06:12 AM
Last Post: mikeb
