is it possible to install a pinephone pro mainboard in a pinephone
i would like to know if it is possible to install a pinephone pro mainboard in a pinephone for an upgrade of the cpu, ram and storage
(01-22-2023, 01:09 PM)hannescam Wrote: i would like to know if it is possible to install a pinephone pro mainboard in a pinephone for an upgrade of the cpu, ram and storage
That is not possible, the parts are incompatible.
You will find your answer in Pinephone Pro's webpage here.
Specifically
Quote:I am a PinePhone owner – will I be able to upgrade it by installing a PinePhone Pro mainboard?
Probably not. While the PinePhone Pro’s mainboard will fit the PinePhone, the chassis, IPS display panel, cameras, the daughterboard, and thermal dissipation systems are all different. For instance, the PinePhone Pro’s cameras will not fit into the PinePhone chassis and are electrically incompatible with the PinePhone’s mainboard. Software enablement would also be required to drive the original PinePhone’s components (such as the LCD) using the PinePhone Pro’s mainboard. Thermal dissipation is another important consideration, as the higher heat output may not be trivial to overcome in the original PinePhone’s chassis.
thankyou for your answer
Specifically
Don't the wiki state the pine phone as using the same screen as the pro?
(07-10-2023, 10:11 AM)brken Wrote: Don't the wiki state the pine phone as using the same screen as the pro?
PinePhone and PinePhone Pro using different LCD panel.
The answer is actually a 'lil bit more nuanced than "No, they're incompatible"
Someone could absolutely print an appropriately shaped phone housing with
new LCD screen drivers for the pro's board, and the correctly shaped ribbon cables.
So, yeeees? it is, but without financial incentive, it's unlikely anyone will make this happen.
Specifically
The wiki does not state that, no.
  PinePhone Pro EDL boot by shorting contacts ozkenlc 1 158 05-01-2024, 09:29 AM
Last Post: traut
Thumbs Up Pinephone Pro + Keyboard for sale Jimmy88 2 824 04-22-2024, 08:38 PM
Last Post: AegisWages
  PinePhone only turns on sometimes zvavybir 1 435 03-27-2024, 12:19 PM
Last Post: zvavybir
  PinePhone Pro Explorer's edition Qualcomm modem recovery shifras 7 1,273 03-24-2024, 02:22 PM
Last Post: zetabeta
Question Screen turning off and booting problems with the Pinephone Pro xnZwJR6vys9a2wm7yWE4 0 247 01-16-2024, 02:38 PM
Last Post: xnZwJR6vys9a2wm7yWE4
  Pinephone Pro LCD and Touchscreen Hobgoblin 8 3,889 01-14-2024, 02:50 PM
Last Post: shifras
  Recurrent problems with broken charger chip on the pinephone/pinephone pro keyboard Jite 4 1,225 11-18-2023, 07:25 AM
Last Post: crocspot
  Pinephone pro packet injection for internal wifi chipset covar 1 846 08-13-2023, 04:40 AM
Last Post: fxc
  PinePhone Keyboard won't work. read_kb_reg(PPKB_SYS_CONFIG) needs what? jovval 0 537 07-09-2023, 09:03 PM
Last Post: jovval
Photo My PinePhone Pro does not read the micro SD card at all. tux_life 7 2,753 03-26-2023, 02:55 AM
Last Post: tux_life
