How to install fbkeyboard on PostmarketOS?
I'm trying to find simple instructions for how to compile and implement fbkeyboard so it's running at TTY when it asks for login/password on PostmarketOS.
Repo: https://github.com/julianwi/fbkeyboard
Example of it running at tty login on a Pinephone: https://youtu.be/npKwMWr1F_0?t=1099
I've searched around a while but can't seem to find much. The repo's readme is somewhat helpful but i'm not used to Alpine's musl compiler or how to auto-start a program so it's runs at the TTY prompt.
Much thanks for any suggestions and if I find the answer i'll post it here.
The best answer was I needed to update to the latest pmOS which has TTYEscape which allows you to switch to TTY2 and launches the keyboard `buffyboard`, then kills it if you use the same combo to switch back. See: https://wiki.postmarketos.org/wiki/TTYescape
If you're not using TTYEscape a keyboard like `fbkeyboard` or `buffyboard` needs to be running as a service but that service needs to be stopped before switching to a TTY running a compositor or it'll continue to pick up finger presses in the background and type text.
To install fbkeyboard and it's service:
sudo apk add postmarketos-ui-fbkeyboard
sudo rc-service fbkeyboard start
  install iso from sd card to emmc aular 2 330 03-11-2024, 10:24 PM
  Temporary fix for Modem Not Coming Back on in SXMO Postmarketos Pinephone kebab 2 2,109 07-16-2023, 11:14 AM
Last Post: kebab
  Error while dist upgrade PostmarketOS shellchocolat 0 726 03-16-2023, 02:56 AM
Last Post: shellchocolat
  postmarketOS fixed battery issues Deadladyofclowntown 1 1,543 06-23-2022, 02:44 PM
Last Post: zer0sig
  SIM Card Install pineme 4 5,142 06-10-2022, 03:15 AM
Last Post: rocket2nfinity
  My Pine doesn't allow me to install to eMMC on different OS's Kimberley van Buyten 1 1,365 05-31-2022, 04:26 PM
Last Post: fxc
  Selling Pinephone PostmarketOS Convergence Edition pentamassiv 0 1,076 03-22-2022, 06:33 PM
Last Post: pentamassiv
  "KB151 was not detected on bus" after failed package install matthew_exon 3 2,319 03-11-2022, 09:02 AM
Last Post: Danct12
  unable to install any software pine-user1 2 1,527 11-09-2021, 01:07 AM
Last Post: ryo
Sad LTE data does not work on T-Mobile US with latest postmarketOS 21.06 SP3 PacificSinewave 1 1,400 11-07-2021, 10:15 AM
Last Post: beta-user
