"KB151 was not detected on bus" after failed package install
I'm using the Manjaro ARM Beta, not sure which version.  I wanted to be able to compile code on my phone so I tried to install some packages:
  1) autoconf  2) automake  3) binutils  4) bison  5) fakeroot  6) file  7) findutils  8) flex  9) gawk  10) gcc  11) gettext  12) grep  13) groff  14) gzip  15) libtool  16) m4
  17) make  18) pacman  19) patch  20) pkgconf  21) sed  22) sudo  23) texinfo  24) which
I don't have a copy of the output of what happened, but it failed.  Now when I boot I get the Manjaro logo for a while and then (this is transcribed from tiny text and probably has errors):
[    0.216425] lima 1c40000.gpu: dev_pm_opp_set_regulators: no regulator (null) found: -19
[    1.871112] kb151 2-0015: KB151 was not detected on the bus (-6)
Is there any way to recover from this?
I'm not completely certain which version of the beta this is.  I installed it a few months ago and used software update a few times.  I have an image of the root filesystem to recover files, but unfortunately I don't have a Linux machine I can use to change anything directly on the card.
KB151 is the keyboard case addon, if you don't use it then the error can be safely ignored.
Find me in the forest, when I'm at my lowest. I don't really think you should continue..
HOLD YOUR BREATH.
(03-10-2022, 11:41 PM)Danct12 Wrote: KB151 is the keyboard case addon, if you don't use it then the error can be safely ignored.
OK, good to know, but it never boots any further than that.  So presumably it's failing to boot because of something else, not related to the keyboard?
Yep!
HOLD YOUR BREATH.
  install iso from sd card to emmc aular 2 173 03-11-2024, 10:24 PM
  no sdcard boot and manjaro update failed Gwen 3 1,302 11-27-2022, 07:56 AM
Last Post: fxc
  pinephone-support package not upgradable on Mobian fhireman 4 2,210 09-24-2022, 08:01 AM
Last Post: dante404
  How to install fbkeyboard on PostmarketOS? Ulfnic 1 1,055 09-12-2022, 07:49 PM
Last Post: Ulfnic
Rainbow New Pinephone for sale, Beta w Convergence Package megst 0 708 07-26-2022, 11:40 AM
Last Post: megst
  SIM Card Install pineme 4 4,997 06-10-2022, 03:15 AM
Last Post: rocket2nfinity
  My Pine doesn't allow me to install to eMMC on different OS's Kimberley van Buyten 1 1,298 05-31-2022, 04:26 PM
Last Post: fxc
  WTS: (Rarely used) Pinephone Beta Edition with Convergence Package - DHL shipping vatin 3 1,903 05-25-2022, 04:31 PM
Last Post: vatin
  Won't boot - Failed to read Who-Am-I register nocargo 6 5,296 04-30-2022, 06:11 PM
Last Post: TRS-80
  PinePhone to sell ; Community Edition Manjaro + Convergence Package Gribouille 6 4,964 11-28-2021, 06:52 AM
Last Post: Gribouille
