Warning!!- sim card adapter destroyed my sim card holder on my pine phone pro
(05-15-2022, 04:36 AM)fxc Wrote:
(03-26-2022, 07:29 PM)bcnaz Wrote: There should be some notices on this weakness  !
A Friend just wiped out her brand new Pro phone just by "using this Adapter" ..!
What is worse yet  ?
How about you cannot even buy a new Pro motherboad !
You MUST but Another Complete phone,  because you used an adapter that came with your phone....
I would suggest to open a ticket under support.pine64.org regarding a replacement. Attaching a picture of the defect to the ticket is advised.
For clarifications, there are big warnings on both, the wiki and the printed manuals (see https://wiki.pine64.org/wiki/PinePhone_P...time_setup and https://wiki.pine64.org/wiki/PinePhone#F...stallation). The mainboard is only currently not yet available in the store, I think the regular PinePhone's Braveheart Edition didn't have replacement parts and mainboards in the store back then either and I assume it makes sense for Pine not to produce a large amount of replacement mainboards if a new hardware revision is possible for the next batch. The mainboard itself will probably be however a large part of the overall phone price.
Well what I think is that the main board as a whole is never replaced. May be there is a part which is supposed to be replaced. And I hope it will be an easy task for pine to repair it.
What is worse yet  ?
For clarifications, there are big warnings on both, the wiki and the printed manuals (see https://wiki.pine64.org/wiki/PinePhone_Przameen and https://wiki.pine64.org/wiki/PinePhone#F...stallation). The mainboard is only currently not yet available in the store, I think the regular PinePhone's Braveheart Edition didn't have replacement parts and mainboards in the store back then either and I assume it makes sense for Pine not to produce a large amount of replacement mainboards if a new hardware revision is possible for the next batch. The mainboard itself will probably be however a large part of the overall phone price.
Could you clarify the question? I have trouble understanding it. The mainboards as whole can be replaced individually and from what I know should be in the store quite soon. Replacing the SIM card slot individually is not advised, as it is quite difficult for soldering experts.
  Anyone yet received replacement sim/sd card holder tckosvic 19 9,029 06-16-2023, 12:20 PM
Last Post: fxc
Photo My PinePhone Pro does not read the micro SD card at all. tux_life 7 2,638 03-26-2023, 02:55 AM
Last Post: tux_life
  New out of box phone, vibrates and solid red light on charging StuckInTheCloud 1 909 03-24-2023, 03:12 PM
Last Post: fxc
  Question on the keyboard battery with phone knoxvilles_joker 0 1,061 08-27-2022, 12:04 AM
Last Post: knoxvilles_joker
  PinePhone Pro Motherboard with sim card holder tckosvic 1 1,614 08-22-2022, 06:42 PM
  Pine Store : Pine phone Pro Parts ? bcnaz 7 4,401 04-08-2022, 09:45 PM
Last Post: bcnaz
  Pine Phone Pro issues gmastap 0 1,210 03-14-2022, 07:21 AM
Last Post: gmastap
  Replace PPP sim card/sd card slot hardware tckosvic 5 4,124 03-13-2022, 12:20 PM
Last Post: tckosvic
  How to remove the sim card liberty1234 6 4,269 02-16-2022, 01:27 PM
Last Post: ragreenburg
  SD Card insertion depth nristen 4 2,996 02-03-2022, 01:27 PM
Last Post: nristen
