enble boot after power loss/restore
(06-18-2022, 09:54 PM)gechu Wrote: Are you thinking about this watchdog ESP32 Reset Circuit?
not specifically that but just an esp (or another sbc) with a relay.  I can control power cycle relay via mqtt message and some watching code elsewhere  (likely example  uptime kuma that I run which can do mqtt notifications via appraise. )
https://github.com/louislam/uptime-kuma
FYI, as an alternative to the "dedicated" watchdog board one can buy this pretty cheap esp32 dev board with built in relay and power supply. https://www.aliexpress.com/item/1005003651506570.html?
If you put tasmota on it you can program it with berry scripting to be a watchdog.
Well, finally got around to trying my idea of a 20K ohm resistor to ground.
at 20K ohm got the time off down to about 15 secs for successful powerloss boot
but 10K ohm resistor was perfect.  I can pull the plug, immediately put it back in and it will reboot.
I'm going to so this with all my headless rockpro64 (i.e. NAS boxes).
I'm calling this solved.   Pine isn't likely to change this board at this point BUT hopefully this is not an issue with future boards like star64 which looks to be its replacement.
(06-19-2023, 12:33 PM)dkebler Wrote: Well, finally got around to trying my idea of a 20K ohm resistor to ground.
Nice!
Can you write / link to a guide?
I've spent 15+ years as an IT professional, but tech at this level, I know very little about
[attachment=2797 Wrote:gechu pid='118142' dateline='1687199855']
Nice!
pretty simple.   take pair of jumper wires, put in a 10K ohm resister across one end (I cut the leads down), cover it with shrink.  Take the other pair at the other end.  put them on pins 4 and 6 (5v and ground) but any 5v and ground should work.  I put a bit of hotglue on them so it's easier to get them on together.   see pic
Thanks! This is definitely outside of my comfort zone! Going to try anyways
It's great that you've already experienced the desired behavior with one of your RockPro64 boards. While troubleshooting the second board, checking for potential jumper settings or seeking guidance from the Armbian community can help resolve the issue.
This is final solution.  I have built and coded a hardware poweron watchdog
See details here.
https://gist.github.com/dkebler/aa02d96e...f345a095af
(06-02-2022, 01:29 PM)gechu Wrote:
(04-18-2022, 03:58 AM)ok38 Wrote: OK, I found. I just needed to add RTC battery.
Thanks.
I ordered a RTC BACKUP BATTERY HOLDER - CR-2032. But it still doesn't resume automatically after power failure.
Did you get the RTC BACKUP BATTERY HOLDER – 2 X AAA?
Sorry, it is way too late. I don't have the holder just a connector and the battery (CR2032). The only thing I did was to flash U-boot to be able to boot from S-ATA but I did not found with which one it was. And I do not know if there is a link between them.
  Mainline U-Boot with SPI, NVMe and SATA boot support sigmaris 108 119,814 09-25-2023, 12:46 AM
Last Post: ChriChri
Bug Broken boot: What am I missing? mkosarek 1 675 09-08-2023, 08:14 AM
  Unable to boot Armbian on new RockPro64 mooseball 5 4,274 07-14-2023, 08:59 AM
Last Post: rockjonn
  no boot white led flashing moserwi 7 4,332 05-18-2023, 10:46 AM
  PCIE interface power on too late Slark Xiao 0 1,019 11-29-2022, 11:56 PM
Last Post: Slark Xiao
  Automatic power on after power outage gechu 1 2,742 11-17-2022, 06:13 PM
Last Post: acj_
  u-boot locked on pine64pro ljones 1 1,555 09-06-2022, 10:32 AM
Last Post: ljones
  Cannot get my board to boot deutschlmao 11 8,229 09-05-2022, 04:23 PM
Last Post: ljones
  After Power Loss feature working bdherouville 2 2,238 08-22-2022, 03:52 AM
Last Post: bdherouville
  U-BOOT Tutorial hazz 0 1,155 07-19-2022, 10:48 PM
Last Post: hazz
