Pine64+ Connections
I was asked to post a picture showing my connections for the LCD touchscreen. Here you go.
Thank you, Steve!
... I assume the silvered connections are down (other side from the blue stripe) and that there are only connections on one side?
Did you have to lift up on the connector latch, or were you able to just slide the connection in (zero force insertion?).
Thanks again.
marcus
marcus,
You are correct in that the sliver side, or contacts, face downward.
With the connectors themselves, you need to lift up the black tabs, slide the cable in flush to the connector as far as it will go,
and then close the black tab. You cannot slide the cables in without opening the tabs.
(07-01-2016, 09:02 PM)Steve409 Wrote: marcus,
Is that the touch screen from Pine64 or some other screen? If it's the Pine screen, did it come with the extender or did you have to find that somewhere else?
Also it's hard to tell in the picture whether it's mounted inside a homemade cardboard or wood case, or just sitting on top of one. Either way it looks cool. I ordered a couple of the ABS cases but I keep seeing other random containers and thinking they would make decent cases for a pine64 or rpi.
psychedup,
That is the LCD that came from Pine64. You're right, they are just setting on top of each other (separated with a napkin)!
I ordered the case, but it has not been shipped yet.
Also, the extender cable and cable adapter came with the board! They also included a push button switch that I can solder into the Power or Reset location!
(07-01-2016, 11:43 AM)Steve409 Wrote: I was asked to post a picture showing my connections for the LCD touchscreen. Here you go.
Thank you!
Unfortunately it is not sufficient. Where can we find a video or, at least, a series of pictures explaining each step?
Thanks in advance.
When I get mine, I'll make one, I promise; some folks need a photo journal of each step...
(07-04-2016, 03:54 PM)MarkHaysHarris777 Wrote: When I get mine, I'll make one, I promise; some folks need a photo journal of each step...
Thank you. I just got this thread: http://edthadba.blogspot.com/2016/06/con...d-lcd.html
I hope to try it today.
  Wi-Fi/Bluetooth for PINE64, Model: Sopine A64 lamson 0 1,770 08-24-2021, 08:17 AM
Last Post: lamson
  AC Adapter Which One? Pine64 A64 DB V1.1 2GB REV B (Year 2016) databaseprogrammer 2 3,489 06-17-2021, 05:35 AM
Last Post: kqlnut
  Just discovered Pine64 ! - first Q philip_rhoades 4 5,799 04-29-2020, 10:13 AM
  A newest user in Pine64 Aliko 1 4,006 04-19-2020, 10:33 PM
  PINE64 Installer - Simple Way to Image Your MicroSD pineadmin 101 151,753 01-15-2020, 12:46 PM
  Emails from pine64 received as spam by gmail Matan 2 5,822 08-21-2019, 08:30 AM
Last Post: Leiaz
  How to handle a Pine64 correctly gbjensen 6 16,426 03-28-2019, 11:43 PM
Last Post: InsideJob
Information Creating a NAS server in Pine64 javi_cala 4 8,377 01-21-2019, 02:03 AM
Last Post: bartes
  The 6 most common reasons why Pine64 won't boot Andrew2 109 210,201 10-11-2018, 11:35 PM
Last Post: Technolab88
  Pine64 installer way slow flashing Paraplegic Racehorse 2 4,546 01-10-2018, 04:05 PM
Last Post: dkryder
