PSU for keyboard case battery PD+QC
OK I have a charger with a USB-C to USB-C cable. The outlet on the charger says "PD+QC" and is rated 5Vx3A which I want to use to charge the keyboard case battery, but also lists other voltages and currents. The voltages and currents for QC are different again.
I have read around a bit, PD is OK for the PinePhone keyboard case ( https://xnux.eu/pinephone-keyboard/faq.html#chargers ). The QC appears to be a Qualcomm "standard" that only is activated when it encounters one of their chipsets that has QC activated https://en.wikipedia.org/wiki/Quick_Charge
So am I correct in thinking that although the outlet is labelled "PD+QC" that it will only present the PD supply to the PinePhone? Also that the correct voltage will be set for the PinePhone?
(01-29-2022, 08:06 AM)grump_fiddle_reinstall Wrote: OK I have a charger with a USB-C to USB-C cable. The outlet on the charger says "PD+QC" and is rated 5Vx3A which I want to use to charge the keyboard case battery, but also lists other voltages and currents. The voltages and currents for QC are different again.
Your assumption is correct, only PD supply to PinePhone and 5V3A will be selected.
  Case for Pinephone totilele 13 7,536 04-11-2024, 11:48 AM
Last Post: gramonyl
  Slip/Zippered Case for PP/KB? jakfish 0 301 03-03-2024, 04:55 PM
Last Post: jakfish
  keyboard case charging but not typing new2pinephone 18 5,959 02-19-2024, 07:30 AM
Last Post: theResonant
  Keyboard doesn't charge my phone no matter what, so can I charge my phone directly ragreenburg 3 10,242 01-14-2024, 03:34 PM
Last Post: acid andy
  I've added an I2C connector to the PP keyboard eugenr 0 452 11-26-2023, 07:24 AM
Last Post: eugenr
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,265 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 468 10-22-2023, 03:39 PM
Last Post: rotwang
Exclamation USB mouse isn't working when a PP keyboard is attached? mikeb 3 1,278 10-21-2023, 08:21 PM
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 537 10-21-2023, 07:50 AM
  Which mini keyboard and mouse to choose for the PP? Peter Gamma 0 637 10-21-2023, 02:55 AM
