PinePhone Keyboard on other phone/over USB
I recently got a Fairphone 4 but I'd really like to use that keyboard.
Adapting the physical space for the phone shouldn't be hard, considering that I have a 3D printer. I have done similar work before.
Obviously, though, I wouldn't be able to use the original connector, and probably not even the original connection protocol, since I can only connect USB to the Fairphone.
Is it possible to connect the keyboard using USB? I've seen in some video, that (at least an older preproduction version of the keyboard) has an internal USB connector. Does this connector send HID? If not by default, would it be possible for me to modify the firmware to output HID over USB?
Now, that Linux kernel 6.1 supports the keyboard, there should be much better chances to use the keyboard for other devices, Let's see and search ...
  Case for Pinephone totilele 13 7,233 04-11-2024, 11:48 AM
Last Post: gramonyl
  keyboard case charging but not typing new2pinephone 18 5,764 02-19-2024, 07:30 AM
Last Post: theResonant
  Keyboard doesn't charge my phone no matter what, so can I charge my phone directly ragreenburg 3 8,488 01-14-2024, 03:34 PM
Last Post: acid andy
  PinePhone Dock with laptop? Mikey1977Y2J 2 635 12-12-2023, 05:43 PM
Last Post: Mikey1977Y2J
  I've added an I2C connector to the PP keyboard eugenr 0 424 11-26-2023, 07:24 AM
Last Post: eugenr
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,166 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 449 10-22-2023, 03:39 PM
Last Post: rotwang
Exclamation USB mouse isn't working when a PP keyboard is attached? mikeb 3 1,232 10-21-2023, 08:21 PM
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 514 10-21-2023, 07:50 AM
  Which mini keyboard and mouse to choose for the PP? Peter Gamma 0 615 10-21-2023, 02:55 AM
