Getting Newer Version of Nheko
I wanted to use Nheko as my Matrix client on Mobian but the version that is in the repo is too old due to needing bug fixes that newer versions have. I see that Nheko has a Flatpack version, has anybody had any success installing that on the Pinephone ? I tried running the command:
flatpak install flathub io.github.NhekoReborn.Nheko
and got the message "error: No remote refs found similar to 'flathub'"
PinePhone BraveHeart Edition
Pinephone Convergence
PineTab
RockPro64
Out of all the Matrix clients I tried, only Mirage actually worked (although super laggy).
And Weechat of course without lag, but that's an IRC client that happens to have a Matrix plugin.
I tried to install Nheko before, but I couldn't run it I think.
母語は日本語ですが、英語も喋れます(ry
So I got it working. What I had to do beforte entering the command I did above was enter
"flatpak remote-add --if-not-exists flathub https://flathub.org/repo/flathub.flatpakrepo"
(10-27-2021, 03:30 AM)ryo Wrote: Out of all the Matrix clients I tried, only Mirage actually worked (although super laggy).
Nheko is one of the few Matrix clients to support E2E which is why I wanted to use it. It is also the only one I have tried where E2E is able to be setup from a simple toggle from the menu and also the only client I have seen where you can adjust scaling from the options menu.
PineTab
RockPro64
  apt trying to install a package version not in the repo chainingsolid 1 545 11-12-2023, 03:54 AM
Last Post: evilbunny
  Nheko - Missing GStreamer plugins videoconvert freelectro 4 1,814 03-04-2023, 11:12 PM
  Can't Get Nheko To Work [never mind, it's a bug] el.pollo.diablo 0 832 08-02-2022, 02:11 AM
Last Post: el.pollo.diablo
  [Solved] How to get a kernel newer than 5.10 on Mobian ? gab 0 1,405 08-26-2021, 04:08 PM
Last Post: gab
  Download Latest Version through wget/curl pizzalovingnerd 1 3,197 06-20-2020, 03:30 AM
Last Post: rico
