[Solved] How to get a kernel newer than 5.10 on Mobian ?
Q: I only see the kernel linux-image-5.10-sunxi64 in apt. I am running bullseye. How can I get a newer kernel ?
A: At the time of writing, 5.10 is the latest image available in bullseye for the Pinephone. To get a more recent kernel you will have to upgrade to a newer version. For instance after switching to bookworm you can install linux-image-5.13-sunxi64
(Sorry if this is noise. I post this in the hope the search engines will find it: I had to ask the kind folks on the Mobian's Matrix/Telegram channel to figure that).
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 17 2,107 Yesterday, 05:47 AM
Last Post: diederik
  Mobian repository status henrythemouse 16 8,805 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 139 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,020 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,839 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 642 09-01-2023, 11:29 AM
Last Post: Mahgue
Big Grin An early xmas present: 6.1 kernel treebeard 28 9,970 07-18-2023, 03:14 AM
Last Post: gischpelino
  how to update mobian over tor vusra 13 6,941 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,910 07-09-2023, 01:37 AM
Last Post: vusra
  how to disable ipv6 at kernel level with towboot? vusra 2 918 07-09-2023, 01:25 AM
Last Post: vusra
