Pinephone not receiving SMS. SMS not showing on modem either.
Haven't received sms for about a week. I am able to send SMS. I am on Mobian and phosh. My carrier is Verizon
Here is what I have tried:
  • running the mmcli to check for and delete sms. However MMCLI claims there is no messages.
  • Janky-mms which I think probably just uses mmcli and had the same result.
  • minicom -D /dev/ttyUSB2 with a couple of different commands (I can't find where I got these commands but they were supposed to clear the cache and reset the modem I think.)
  • Changing APN
  • Ran the following to check for messages on modem. Like above it showed nothing
    socat - /dev/ttyUSB10,crnl
    AT+CMGL
I don't know if Journalctl shows anything interseting but here it is should anyone want to see it
https://pastebin.com/H8KxJUyK
Thanks in advance for any help.
Sorry I can't help about your provider.
Since the last update of Saturday, I could receive and send SMS.
In the Parameters application, what can you see in the 'Modem Details' ?
(03-22-2021, 03:34 PM)Gribouille Wrote: Sorry I can't help about your provider.
Carrier: Verixon
Network Type: lte
Signal Strength: 49%
Network Status: Registered
Manufacturer: QualComm Incorporated
Model: Quectel Mobile Broadband
Firmware Version: EG 25GGBR07A08M2G
IMEI 867698044818253
Carrier: Verixon
Network Type: lte
IMEI: xxxxxxxxxxxxxxxx
Same network type and firmware for me.
I changed a setting inside the vzwinternet apn to allow data when roaming. I think I was tinkering and forgot I changed it. For some reason having that set to on blocks all incoming sms. Unfortunately it appears all the previous sms that I should have received are gone and I won't be receiving them.
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 25 2,493 10 minutes ago
Last Post: treebeard
  unofficial kali linux for pinephone help needed pinesmell 5 3,714 01-08-2024, 02:50 PM
Last Post: ERPlegend
  MODEM - Usb problem & couldn't query SIM slots: QMI protocol freelectro 5 2,923 06-06-2023, 06:36 AM
Last Post: freelectro
  Axolotl on PinePhone / Mobian arno_nuehm 219 168,027 03-26-2023, 01:49 AM
Last Post: shulamy
  PinePhone won't boot after software update jb2000 2 1,366 03-17-2023, 07:26 AM
Wink Pinephone lost graphic during mobian system upgrade cmpin 4 2,250 03-01-2023, 04:45 PM
Last Post: anonymous
  ModemManager debug mode? (Needed to flash modem) calinb 1 1,238 02-27-2023, 04:18 PM
Last Post: calinb
  Battery problem with a Pinephone keyboard and Mobian elode 2 2,239 12-22-2022, 07:10 PM
Last Post: acid andy
  Modem Firmware Upgrade - Modem Busy - USB Issues biketool 10 4,898 09-23-2022, 05:15 AM
  Sending Pinephone SMS from Desktop biketool 5 3,000 09-13-2022, 01:46 PM
