OpenTTD game - Error: no usable screen resolutions found.
I'm trying to run OpenTTD on mobian pinephone and it doesn't work. I see that error above when starting it from the terminal. Trying to set a resolution manually with the -r flag didn't helped.
However if I run it with:
$ openttd -v dedicated
then I have no errors but no picture/window, only music playing. I tried also to start it in fullscreen by changing the opentdd.cfg file. Nothing new happened.
Does anybody succeed in running this game? How?
Thanks,
  Eugen
(03-15-2021, 05:34 AM)eugenr Wrote: I'm trying to run OpenTTD on mobian pinephone and it doesn't work. I see that error above when starting it from the terminal. Trying to set a resolution manually with the -r flag didn't helped.
Thanks,
  Eugen
https://github.com/OpenTTD/OpenTTD/issues/8029
(03-15-2021, 09:47 AM)tmschmitz Wrote: https://github.com/OpenTTD/OpenTTD/issues/8029
Using that I managed to run it with this command:
$ SDL_VIDEODRIVER=wayland openttd -v sdl:no_threads
Thanks!
  Screen auto-rotation sensitivity mdk 0 305 12-26-2023, 06:08 AM
Last Post: mdk
  [Megapixels] Flash strobe, pictures viewer and MPCamera error 22 freelectro 1 1,167 08-30-2023, 03:59 AM
Last Post: karensather
  Screen stay black unless power key pressed short freelectro 0 688 06-24-2023, 01:55 PM
Last Post: freelectro
  Unsuspend → Black screen mdk 15 5,469 06-22-2023, 11:20 AM
Last Post: Melechtna
  Boot log analyses -> GPU no regulator (mali) found freelectro 0 1,001 03-06-2023, 12:06 PM
  Lock screen question: always squeekboard tuxcall 1 1,262 02-02-2023, 08:51 PM
Last Post: Haibara23
  [solved] Black screen at boot time mdk 0 1,035 01-13-2023, 03:33 AM
Last Post: mdk
Exclamation No modems were found: No mobile data, no 2G anonymous 2 1,440 12-26-2022, 06:46 PM
Last Post: anonymous
  how to split screen? andrew907 2 1,597 08-08-2022, 09:38 AM
Last Post: andrew907
  Proximity sensor is oversensitive (was "Screen blanks when making call") treebeard 5 2,928 08-02-2022, 03:16 PM
Last Post: treebeard
