Screen is blank on pinecil - did I kill it?
I was using my pinecil today to do some soldering, I was running it off of my power bank cause I thought it would be enough power.  I ended up having issues with one of the larger components so I decided to pull out my AC adapter that I have to get some extra power.
I have a 24v AC adapter that I had bought for my TS100.  I plugged that up and when I plugged it into the pinecil I got nothing.  I then plugged it back into the power bank and the screen was still blank.
I do have a USB power meter plugged in between the power bank and the pinecil.  It shows 5v 0.3a when plugged in, so it's not completely dead.
I plugged my TS100 into the AC adapter and it worked fine.  I know they now recommend 21v max now, but I was under the impression it could handle the 24v just fine.  I am assuming this is my issue since it worked fine until I switched power supplies, but would that cause what I am experiencing?  Is there any place to buy replacement screens for the pinecil?  I know I can buy screens for the TS100, are the compatible?
Open to any and all suggestions.  Thank you.
Hey! Did you get an answer to this? I did the same with the same result and am not sure if I need a new one
Hi Gents,
Same thing happened to me.  I can get the Pinecil to flash over dfu mode...  where you able to revive it?
Maybe hop over to the GitHub discussion if you're still trying to fix it.... https://github.com/Ralim/IronOS/discussions/988
-DD
Question Can Pinecil Read USB-C Cable E-Marker Chips? Garywoo 0 128 04-23-2024, 01:48 PM
Last Post: Garywoo
  Connecting a power supply to the Pinecil jon_bondy 1 451 02-29-2024, 07:37 PM
Last Post: Okedokey
  Crippling noise from inside pinecil during a few minutes high power soldering. dreieck 2 878 01-31-2024, 12:34 AM
Last Post: suga7
Question Pinecil Tempaerature Reading jumps to Y400°C when active but stays normal when cold H3wastooshort 0 421 12-24-2023, 05:45 PM
Last Post: H3wastooshort
  Asus laptop power supply can also power Pinecil biketool 9 8,508 11-17-2023, 12:57 PM
Last Post: killingmesmalls
  Mass problem Pinecil V2 Harrysteed 0 729 11-02-2023, 09:11 AM
Last Post: Harrysteed
Question Pinecil v2 power cycles at higher voltages? clemon79 2 1,377 10-09-2023, 10:10 PM
Last Post: clemon79
  PD resets during heat up tip [Pinecil V2] Neitron4ik 2 1,636 10-09-2023, 01:22 AM
Last Post: Neitron4ik
  [Hackaday Article] All About USB-C: Pinecil Soldering Iron vajak 1 1,529 02-02-2023, 11:45 AM
Last Post: VaZso
  Brand new Pinecil v2 won't boot on PD jhutch 1 2,331 12-14-2022, 01:03 AM
Last Post: River
