Dead pinecil
Hi all,
When I got my pinecil, I powered it up to verify it works - it was on for less than a minute.  When I tried to use it tonight, it's completely dead.  It doesn't do anything when power is applied via barrel plug nor USB C.  Went to look into reporting to support, and the link from the page Warranty Policy - PINE STORE (pine64.com) goes to https://support.pine64.org/  - which gives a security cert warning.  Unsure how else to get ahold of Pine support.
I think I may know what the issue is - my power supply is set to 24 volts, which is what I've used with my TS100, and RC charging rig forever.  I've seen several places that say that the barrel plug can take 24v, but others that say 20v or 21v.    The wiki - Pinecil - PINE64 even says "Recommend operating voltage 12-21V, maximum rating at 24V"  right below "12V- 24V DC5525 Barrel Jack"
Anyway - did I overvolt and burn it up?  What specifically would i have burned (didn't open it up yet to look). Repairable?
24 volt is fine since it is within the temperature on their website.
I would recommend opening a ticket with the support to get a new one or a refund.
Best Regards, Julius
I clicked through the scary invalid security cert for https://support.pine64.org/ which forwarded me to pine's zoho support site. I opened a case to see what my options are. If someone from pine sees this, you should either update your security cert to include the above link, or change the link on the warranty page to go directly to the zoho support site.
Yeah, a simple wildcard cert would be a good idea.
it doesn't get happy
it doesn't get sad
it just runs programs
Question Can Pinecil Read USB-C Cable E-Marker Chips? Garywoo 1 162 2 hours ago
  Connecting a power supply to the Pinecil jon_bondy 1 471 02-29-2024, 07:37 PM
Last Post: Okedokey
  Crippling noise from inside pinecil during a few minutes high power soldering. dreieck 2 898 01-31-2024, 12:34 AM
Last Post: suga7
Question Pinecil Tempaerature Reading jumps to Y400°C when active but stays normal when cold H3wastooshort 0 431 12-24-2023, 05:45 PM
Last Post: H3wastooshort
  Asus laptop power supply can also power Pinecil biketool 9 8,539 11-17-2023, 12:57 PM
Last Post: killingmesmalls
  Mass problem Pinecil V2 Harrysteed 0 741 11-02-2023, 09:11 AM
Last Post: Harrysteed
Question Pinecil v2 power cycles at higher voltages? clemon79 2 1,395 10-09-2023, 10:10 PM
Last Post: clemon79
  PD resets during heat up tip [Pinecil V2] Neitron4ik 2 1,646 10-09-2023, 01:22 AM
Last Post: Neitron4ik
  [Hackaday Article] All About USB-C: Pinecil Soldering Iron vajak 1 1,543 02-02-2023, 11:45 AM
Last Post: VaZso
  Brand new Pinecil v2 won't boot on PD jhutch 1 2,337 12-14-2022, 01:03 AM
Last Post: River
