Microphone not working on Pinebook Pro
I recently discovered that my microphones are not working. I'm on manjaro testing. Has anyone a working microphone on the Pinebook Pro? If so, which distro are you using?
regards,
Hans-Peter
(02-07-2021, 04:33 AM)vfr400racer Wrote: I recently discovered that my microphones are not working. I'm on manjaro testing. Has anyone a working microphone on the Pinebook Pro? If so, which distro are you using?
regards,
Hans-Peter
Im on Manjaro-ARM kde:5.21.1, kernel:5.7.19
I am having the same issue. I followed the instructions here:
https://wiki.pine64.org/index.php/Pinebook_Pro
Went so far as to taking it apart. I traced to the wiring to the taped holes.
Currently it is not showing up on pavucontrol nor elsewhere.
Help!?
Thanks in advance!
Braan
regards,
Hans-Peter
Help!?
Thanks in advance!
Braan
 I tried another image. I can't remember, if it was mrfixit's or ayufan's image. I got microphone input with that. So it's not the hardware in my case. Seems as if Manjaro is missing microphone support .
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 3 566 8 hours ago
Last Post: segaloco
  Pinebook Pro on Debian 12 Power Issue u974615 1 352 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 291 02-17-2024, 07:06 PM
  New Working nVME gilwood 0 237 02-12-2024, 08:46 AM
Last Post: gilwood
  Pinebook Pro charging issues tomekdev 1 632 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 1,123 11-07-2023, 10:09 AM
Last Post: DrYak
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 130,948 09-13-2023, 03:43 AM
Last Post: k3dAR
  PineBook Pro dead ottahe 9 6,060 01-18-2023, 07:41 PM
Last Post: ottahe
  Pinebook Pro malfunctioned hardware samtux 10 4,478 12-27-2022, 03:31 PM
Last Post: samtux
  PineBook Pro revision 2.2: Wishlist for the hardware issue fixes dsimic 115 137,136 11-30-2022, 04:28 PM
