Command to test vibration motor?
Back when I replaced my cracked screen I managed to damage the vibration motor on the USB-C side board by prying it up in the wrong place and breaking it apart.
I recently bought a replacement USB board with vibrator and installed it but still am not getting the confirming vibration when turning the phone on. Is there a command that can be used to manually test the vibration motor to see if it's doing anything? (Charging is working through the USB port so I know the board is connected.)
running "fbcli" or "fbcli --event message-new-sms" will send a message to feedbackd that should cause a sound to play and vibration
Thanks! This command is useful for me
if you can compile simple programs then following might be for you.
https://github.com/Dejvino/pinephone-toolkit
basically it just send data or strings to certain special files, in case of vibrator motor, they are slightly more complicated than a simple string.
  No boot after upgrade: vibration, red LED, then 2 vibrations and yellow LED 3x5co 1 1,036 01-04-2023, 06:46 PM
Last Post: 3x5co
  German Emergency Alarm System Test arno_nuehm 4 1,957 12-11-2022, 01:44 PM
Last Post: traut
  Vibration motor buzzes uncontrollably with call waiting Zebulon Walton 2 1,565 05-28-2022, 07:32 PM
  How to Make Mobian Boot to Command Line Ubermunchen 4 3,587 11-02-2021, 08:34 AM
Last Post: ryo
  Mobian Constant Vibration tumblingdog 4 4,056 07-10-2021, 02:40 AM
Last Post: aed
  Is there a way to do gnome-authenticator via the command line? motox6 0 1,238 05-06-2021, 10:41 PM
Last Post: motox6
  Installing applicatons via command line Zebulon Walton 2 2,907 12-01-2020, 11:24 AM
  Camera test on Phosh Luke 4 8,076 05-26-2020, 02:44 AM
Last Post: a-wai
