Camera test on Phosh
(05-03-2020, 03:41 PM)Luke Wrote:
Can you link the python app?
Any information on the driver used for camera access?
On Mobian, only /dev/video1 claims video capture capability via the sun6i driver and no controls are reported.
mobian@mobian:~$ v4l2-ctl --list-devices
cedrus (platform:cedrus):
/dev/video0
/dev/media0
sun6i-csi (platform:csi):
/dev/video1
mobian@mobian:~$ v4l2-ctl -d /dev/video0 -D
Driver Info:
Driver name      : cedrus
Card type        : cedrus
Bus info         : platform:cedrus
Driver version   : 5.6.0
Capabilities     : 0x84208000
Video Memory-to-Memory
Streaming
Extended Pix Format
Device Capabilities
Device Caps      : 0x04208000
Streaming
Extended Pix Format
Media Driver Info:
Model            : cedrus
Serial           :
Media version    : 5.6.0
Hardware revision: 0x00000000 (0)
Interface Info:
Type             : V4L Video
Entity Info:
Function         : V4L2 I/O
Pad 0x01000002   : 0: Source
 Link 0x02000008: to remote pad 0x1000004 of entity 'cedrus-proc': Data, Enabled, Immutable
mobian@mobian:~$ v4l2-ctl -d /dev/media0 -D
Unable to detect what device /dev/media0 is, exiting.
mobian@mobian:~$ v4l2-ctl -d /dev/video1 -D
Driver Info:
Driver name      : sun6i-video
Card type        : sun6i-csi
Bus info         : platform:csi
Capabilities     : 0x84200001
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps      : 0x04200001
Video Capture
Streaming
Extended Pix Format
mobian@mobian:~$ v4l2-ctl -L
Codec Controls
       mpeg_2_slice_parameters 0x009909fa (unknown): type=103 flags=has-payload
  mpeg_2_quantization_matrices 0x009909fb (unknown): type=104 flags=has-payload
   h264_sequence_parameter_set 0x00990ce8 (unknown): type=110 flags=has-payload
    h264_picture_parameter_set 0x00990ce9 (unknown): type=111 flags=has-payload
           h264_scaling_matrix 0x00990cea (unknown): type=112 flags=has-payload
         h264_slice_parameters 0x00990ceb (unknown): type=113 flags=has-payload
        h264_decode_parameters 0x00990cec (unknown): type=114 flags=has-payload
              h264_decode_mode 0x00990ced (menu)   : min=0 max=0 default=0 value=0
0: Slice-Based
               h264_start_code 0x00990cee (menu)   : min=0 max=0 default=0 value=0
0: No Start Code
   hevc_sequence_parameter_set 0x00990cf0 (unknown): type=120 flags=has-payload
    hevc_picture_parameter_set 0x00990cf1 (unknown): type=121 flags=has-payload
         hevc_slice_parameters 0x00990cf2 (unknown): type=122 flags=has-payload
              hevc_decode_mode 0x00990cf7 (menu)   : min=0 max=0 default=0 value=0
0: Slice-Based
               hevc_start_code 0x00990cf8 (menu)   : min=0 max=0 default=0 value=0
0: No Start Code
mobian@mobian:~$ v4l2-ctl --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
[0]: 'ST12' (Sunxi Tiled NV12 Format, compressed)
[1]: 'NV12' (Y/CbCr 4:2:0)
https://twongkee.wordpress.com/2020/03/2...phone-pic/ appears to use the ov5640 driver.
Poked around a bit more and there is a dmesg error for the ov5640 device for Mobian.
On pmOS, the camera "works" as a video device without autofocus. A video player is used for the viewfinder and can be used to "take photos".
Yes, last I checked the driver is loaded, but it can't init the camera, not sure what the problem is yet
  camera not usable with trixie? JChdeL 0 590 12-05-2025, 01:45 AM
Last Post: JChdeL
  Switching cameras on PPpro Camera app biketool 0 666 11-11-2025, 10:44 AM
  New camera app gnome-snapshot working on trixie? vusra 4 3,907 04-11-2025, 02:53 AM
Last Post: vusra
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 3,799 01-15-2025, 08:08 PM
  The program doesn`t detect the camera blag0rag 6 5,831 09-17-2024, 03:45 PM
  Command to test vibration motor? Zebulon Walton 3 5,230 11-12-2023, 08:45 PM
Last Post: zetabeta
  Auto start application on Phosh login Zebulon Walton 8 11,454 10-14-2023, 06:29 AM
Last Post: alaraajavamma
  GStreamer Camera Issue (Unsupported pixformat: 0x56595559 with mbus code: 0x3001) sog8b 1 3,490 07-17-2023, 01:49 AM
Last Post: junelung
  Using sway along phosh fdlamotte 2 5,818 05-11-2023, 04:24 PM
Last Post: kabouik
  Mobian + phosh firefox ublock and other overlays display bugs tuxcall 3 4,721 02-24-2023, 12:11 AM
Last Post: nexion
