Vibration motor buzzes uncontrollably with call waiting
Today I had was on a call using the Pinephone and a second call came in (a scam/spam call). What happened is the call I was on was disconnected and the vibration motor came on - and stayed on, would not turn off. Even when the legit guy called back and I picked up the vibration motor just kept going. It did not shut off until the phone was rebooted.
So... when this happens is there some way the vibration can be turned off short of rebooting the phone? (I'm using the "002" factory firmware if that makes a difference.)
sudo killall feedbackd
works for me, to the point I aliased it as 'krt' (kill ring tones) in my .bashrc
Cool, thanks!
What I'd really like is to disable call waiting entirely so a second incoming call goes right to voicemail. However the firmware version currently running in my modem does not accept the commands (just reports an error) and apparently it's only possible to disable call waiting that way for 2G and 3G connections anyway. (Those have been discontinued in my area, I'm using 4G.) That topic was covered here on the board in another thread:
https://forum.pine64.org/showthread.php?...#pid105645
Probably at some point gnome-calls will be updated to handle call waiting better but for now just being able to turn off the alert will do.
  Command to test vibration motor? Zebulon Walton 3 2,103 11-12-2023, 08:45 PM
Last Post: zetabeta
  No boot after upgrade: vibration, red LED, then 2 vibrations and yellow LED 3x5co 1 1,000 01-04-2023, 06:46 PM
Last Post: 3x5co
  Proximity sensor is oversensitive (was "Screen blanks when making call") treebeard 5 2,819 08-02-2022, 03:16 PM
Last Post: treebeard
  Pinephone incoming call / SMS notification no ringing / notification volume dcinoz 3 2,861 06-02-2022, 07:16 AM
Last Post: arkadione
  Glacially slow system updates on Mobian - waiting on boot 20m - 1h bujiraso 5 3,320 03-01-2022, 10:06 AM
Last Post: bujiraso
  Calls : two rings and call cut and restore. Gribouille 0 891 01-14-2022, 07:40 AM
Last Post: Gribouille
  GDM3 Receiving call on login screen d-.-b 4 3,610 10-07-2021, 06:59 PM
Last Post: d-.-b
  Mobian Constant Vibration tumblingdog 4 3,986 07-10-2021, 02:40 AM
Last Post: aed
  phone call using built it app will not go to bluetooth motox6 3 3,603 06-28-2021, 11:03 AM
Last Post: wibble
  How to clear recent call list? Zebulon Walton 2 2,643 03-25-2021, 07:41 PM
