Pinebook Pro screen failure?
I have been using my Pinebook Pro that I received earlier this summer up until this past weekend.
Starting yesterday, when the screen turns on after powering up, I see a gray vertical section on the right side of the screen and a the rest of the screen is just vertical lines in somewhat of the color screen of the Manjaro login screen. I have attached a picture.
Does this look like a hardware failure of some type? Or potentially a loose connection? I am looking for suggestions on what to try next. Thanks!
I would try reconnecting both sides of the screen cable.
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 2 554 04-09-2024, 04:33 AM
Last Post: maxjrh
  Pinebook Pro on Debian 12 Power Issue u974615 1 351 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 291 02-17-2024, 07:06 PM
  Pinebook Pro charging issues tomekdev 1 629 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 1,115 11-07-2023, 10:09 AM
Last Post: DrYak
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 130,824 09-13-2023, 03:43 AM
Last Post: k3dAR
  PineBook Pro dead ottahe 9 6,053 01-18-2023, 07:41 PM
Last Post: ottahe
  Catastrophic failure of bottom screw mounts zackw 2 1,528 12-31-2022, 01:26 PM
Last Post: josmo
  Pinebook Pro malfunctioned hardware samtux 10 4,460 12-27-2022, 03:31 PM
Last Post: samtux
  PineBook Pro revision 2.2: Wishlist for the hardware issue fixes dsimic 115 136,996 11-30-2022, 04:28 PM
