Thermal imaging solution board for the PinePhone board
Hi all,
I just want to share my design for a sensor board that is planned to be used with the PinePhone along with a flex breakout board, I call it the PineEye.
The sensor is the Panasonic AMG8833 which is a grid-array infrared sensor which is used for thermal imaging.
Get design files here:
https://github.com/jnavarro7/pineeye_for_pinephone
Order boards directly from here:
https://oshpark.com/shared_projects/Z65YHSF2
I hope the community likes this projects and maybe start working on drivers which are still needed.
Please let me know of any comments or concerns.
I have done some initial test with the board, the sensor is seen by the PinePhone.
In the future I plan to create different sensor or peripheral boards for the PinePhone.
[Image: 2.png?raw=true]
Presumably it would work with libraries like the adafruit python one:
https://cdn-learn.adafruit.com/downloads...sensor.pdf
If it's aimed at the pinephone rather than more generic usage it should probably have the option to connect direct to the pogo pins similar to the way the breakout cable does. I'd be careful of proximity to the antenna.
I guess you've already seen Martijn Braam's post about the MLX90640:
https://blog.brixit.nl/making-a-backcove...pinephone/
(12-04-2020, 03:36 PM)wibble Wrote: Presumably it would work with libraries like the adafruit python one:
I tried the Adafruit one without success as of today. (Now reading Martjin´s post, as the work is aimed for the Raspberry Pi this might be why).
The direct connection could be for a later stage, the current system is aimed for prototyping.
Thanks a lot for the link, I have not seen it before.  I will for sure take a closer look at Martjin´s work!.
  Case for Pinephone totilele 13 7,494 04-11-2024, 11:48 AM
Last Post: gramonyl
  PinePhone Dock with laptop? Mikey1977Y2J 2 660 12-12-2023, 05:43 PM
Last Post: Mikey1977Y2J
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,252 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 465 10-22-2023, 03:39 PM
Last Post: rotwang
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 533 10-21-2023, 07:50 AM
  Use the Linux Console with the PinePhone Keyboard mburns 2 1,044 10-20-2023, 04:11 PM
Last Post: mburns
  Mouse for the PinePhone? Peter Gamma 21 15,562 10-04-2023, 10:24 AM
  PinePhone Wallet Case Shane 5 5,086 09-17-2023, 12:52 PM
Last Post: J T
  KB: Using bus powered USB peripherals with the pinephone keyboard mounted docsunset 9 37,844 08-07-2023, 06:12 AM
Last Post: mikeb
  PinePhone flex breakout board with Grove female header jnpine 0 648 08-04-2023, 10:47 PM
Last Post: jnpine
