braveheart / 3GB/32GB mainboard troubleshooting screen
hi
I just installed the new 3GB/32GB motherboard on my braveheart
I installed the new JumpDrive 0.6 image on an sd card.
I installed the version of mobian of 13/11/20.
I see the phosh menu then the screen is grey.
when I press the power button I can see the date and the device icons.
once the passwd entered, I have only the grey screen.
Tagging @a-wai as your tag is broken Smile
Problem resolved , it works after re-installed the small rubber part in the proximity sensor area.
(11-23-2020, 05:18 AM)chris_02 Wrote: Problem resolved , it works after re-installed the small rubber part in the proximity sensor area.
Have you taken the photo with a Pinephone?
no it's a screenshot of the martjin's vidéo
  Screen auto-rotation sensitivity mdk 0 278 12-26-2023, 06:08 AM
Last Post: mdk
  Screen stay black unless power key pressed short freelectro 0 663 06-24-2023, 01:55 PM
Last Post: freelectro
  Unsuspend → Black screen mdk 15 5,228 06-22-2023, 11:20 AM
Last Post: Melechtna
  Lock screen question: always squeekboard tuxcall 1 1,237 02-02-2023, 08:51 PM
Last Post: Haibara23
  [solved] Black screen at boot time mdk 0 1,020 01-13-2023, 03:33 AM
Last Post: mdk
  how to split screen? andrew907 2 1,542 08-08-2022, 09:38 AM
Last Post: andrew907
  Proximity sensor is oversensitive (was "Screen blanks when making call") treebeard 5 2,830 08-02-2022, 03:16 PM
Last Post: treebeard
  on screen keyboard woes vusra 1 1,254 07-18-2022, 03:29 AM
Last Post: vusra
  Giving certain audio apps priority on the lock screen and pulldown 3x5co 0 864 07-17-2022, 10:34 AM
Last Post: 3x5co
  Won't boot, black screen mdk 4 2,746 07-03-2022, 06:38 PM
Last Post: Chief
