Axolotl on PinePhone / Mobian
#21
(01-25-2021, 05:17 PM)arno_nuehm Wrote:
(01-19-2021, 04:16 PM)dukla2000 Wrote:
(12-16-2020, 07:06 PM)arno_nuehm Wrote: ...
Axolotl 0.9.0.1 is now running with qmlscene on the latest fde-image (20201215). I updated the Mobian Wiki - Manual install.
 I have just followed the steps under "Manual install" with no major problems (BTW npm install ran about 25 minutes) until
mobian@duklapp:~/go/src/github.com/nanu-c/axolotl/axolotl-web$ npm run build
> axolotl-web@0.1.0 build
> vue-cli-service build
⠹  Building for production...
ERROR  Failed to compile with 3 errors        22:09:47
error  in ./src/assets/dark.scss
Module build failed (from ./node_modules/mini-css-extract-plugin/dist/loader.js):
ModuleBuildError: Module build failed (from ./node_modules/sass-loader/dist/cjs.js):
Error: Node Sass does not yet support your current environment: Linux Unsupported architecture (arm64) with Node.js 12.x
For more information on which environments are supported please see:
https://github.com/sass/node-sass/releases/tag/v4.14.1
    at module.exports (/home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/node-sass/lib/binding.js:13:13)
    at Object.<anonymous> (/home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/node-sass/lib/index.js:14:35)
    at Module._compile (internal/modules/cjs/loader.js:999:30)
    at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
    at Module.load (internal/modules/cjs/loader.js:863:32)
    at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    at Module.require (internal/modules/cjs/loader.js:887:19)
    at require (internal/modules/cjs/helpers.js:74:18)
    at getDefaultSassImplementation (/home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/sass-loader/dist/getDefaultSassImplementation.js:24:10)
    at getSassImplementation (/home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/sass-loader/dist/getSassImplementation.js:19:72)
    at Object.loader (/home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/sass-loader/dist/index.js:40:61)
    at /home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/webpack/lib/NormalModule.js:316:20
    at /home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/loader-runner/lib/LoaderRunner.js:367:11
    at /home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/loader-runner/lib/LoaderRunner.js:233:18
    at runSyncOrAsync (/home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/loader-runner/lib/LoaderRunner.js:143:3)
    at iterateNormalLoaders (/home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/loader-runner/lib/LoaderRunner.js:232:2)
    at Array.<anonymous> (/home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/loader-runner/lib/LoaderRunner.js:205:4)
    at Storage.finished (/home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/enhanced-resolve/lib/CachedInputFileSystem.js:55:16)
    at /home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/enhanced-resolve/lib/CachedInputFileSystem.js:91:9
    at /home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/graceful-fs/graceful-fs.js:115:16
    at FSReqCallback.readFileAfterClose [as oncomplete] (internal/fs/read_file_context.js:63:3)
@ ./node_modules/cache-loader/dist/cjs.js??ref--12-0!./node_modules/thread-loader/dist/cjs.js!./node_modules/babel-loader/lib!./node_modules/cache-loader/dist/cjs.js??ref--0-0!./node_modules/vue-loader/lib??vue-loader-options!./src/App.vue?vue&type=script&lang=js& 33:2-30
@ ./src/App.vue?vue&type=script&lang=js&
@ ./src/App.vue
@ ./src/main.js
@ multi ./src/main.js
error  in ./src/assets/light.scss
@ ./node_modules/cache-loader/dist/cjs.js??ref--12-0!./node_modules/thread-loader/dist/cjs.js!./node_modules/babel-loader/lib!./node_modules/cache-loader/dist/cjs.js??ref--0-0!./node_modules/vue-loader/lib??vue-loader-options!./src/App.vue?vue&type=script&lang=js& 35:2-31
@ ./src/App.vue
@ ./src/main.js
error  in ./src/components/Message.vue?vue&type=style&index=0&id=b1b7f866&lang=scss&scoped=true&
    at iterateNormalLoaders (/home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/loader-runner/lib/LoaderRunner.js:221:10)
    at /home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/loader-runner/lib/LoaderRunner.js:236:3
    at context.callback (/home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/loader-runner/lib/LoaderRunner.js:111:13)
    at /home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/cache-loader/dist/index.js:147:7
    at /home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web/node_modules/graceful-fs/graceful-fs.js:57:14
    at FSReqCallback.oncomplete (fs.js:156:23)
@ ./src/components/Message.vue?vue&type=style&index=0&id=b1b7f866&lang=scss&scoped=true& 1:0-532 1:548-551 1:553-1082 1:553-1082
@ ./node_modules/cache-loader/dist/cjs.js??ref--12-0!./node_modules/thread-loader/dist/cjs.js!./node_modules/babel-loader/lib!./node_modules/cache-loader/dist/cjs.js??ref--0-0!./node_modules/vue-loader/lib??vue-loader-options!./src/pages/MessageList.vue?vue&type=script&lang=js&
@ ./src/pages/MessageList.vue?vue&type=script&lang=js&
@ ./src/router/router.js
@ ./src/main.js
ERROR  Build failed with errors.
npm ERR! code 1
npm ERR! path /home/mobian/go/src/github.com/nanu-c/axolotl/axolotl-web
npm ERR! command failed
npm ERR! command sh -c vue-cli-service build
npm ERR! A complete log of this run can be found in:
npm ERR!     /home/mobian/.npm/_logs/2021-01-19T22_09_48_338Z-debug.log
I absolutely haven't a clue what I am doing - I am merely following the recipe, so any suggestions welcome!
TIA
Previous step seems to have been fine:
mobian@duklapp:~/go/src/github.com/nanu-c/axolotl/axolotl-web$ npm install
added 1753 packages, and audited 1820 packages in 25m
7 packages are looking for funding
  run `npm fund` for details
1 low severity vulnerability
To address all issues, run:
  npm audit fix
Run `npm audit` for details.
Hello there,
I tested the manual install of Axolotl 0.9.4 with a fresh Mobian (FDE-Installer 20201215) and all the latest updates. And I got the same error message at
npm run build
I will post an issue on github tomorrow; hopefully 0.9.5 fixes that. I'm still running 0.9.0.1 on my daily driver...
Cheers
Issue resolved.
The rebuild of node-sass didn't work the first time. The second time takes much longer but leads to a successful npm run build.
(01-26-2021, 03:25 PM)arno_nuehm Wrote: ...
Issue resolved.
A huge thank you - started again on a fresh debos build and have Axolotl up and running. First pass through had same errors for re-started from rebuild of node-sass and all went fine.
This is soo exciting: Signal was the one app that I really have missed on my PP - I have migrated lots to Telegram but will be looking to move back to Axolotl!
Thank you again
Issue resolved.
Thank you again
Glad to hear!
I'm so confused how this seems to be working for everyone. I've run the code for the manual install 4 times at this point and it hasn't worked yet. It also isn't spitting out errors to me so I don't know why it isn't working. The last thing that pops up is a message about how a sqlite 3 function my return address of local variables.
(01-31-2021, 07:29 PM)ragreenburg Wrote: I'm so confused how this seems to be working for everyone. I've run the code for the manual install 4 times at this point and it hasn't worked yet. It also isn't spitting out errors to me so I don't know why it isn't working. The last thing that pops up is a message about how a sqlite 3 function my return address of local variables.
that is indeed obscure. Are you running Mobian with all latest updates? And have you performed every command step-by-step?
If you can provide more details here, someone might find a clue.
I will update to Axolotl 0.9.6 today, too. So let's see, if that works for me.
Cheers
Cheers
I am up to date on Mobian and basically what I did was take the code section for the Manual Installation and made that into a shell script and just ran that.
Cheers
My installation of 0.9.6 went fine.
Please follow the commands in the code section step-by-step - it's uncomfortable, but it works. And let me know, if it worked for you.
Cheers
I am getting the sqlite3 error on this line when I do it line by line:
env GOOS=linux GOARCH=arm64 go build -o build/linux-arm64/axolotl .
So should I just try and flash my SD card again and try from there?
Cheers
No, spare yourself the work.
Was it an sqlite3 error or just a warning? And was the go build successful?
If it was just a warning and the build was successful, do the last two cp-commands and create the desktop-files.
It should work then.
(02-01-2021, 08:48 AM)arno_nuehm Wrote: Hi,
Cheers
It works so that I can see the app icon though it unfortunately isn't launching.
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 26 2,683 05-09-2024, 03:08 AM
Last Post: anonymous
  Mobian repository status henrythemouse 16 9,051 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 163 03-18-2024, 08:54 PM
Last Post: penguins_rule
  unofficial kali linux for pinephone help needed pinesmell 5 3,730 01-08-2024, 02:50 PM
Last Post: ERPlegend
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,113 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,897 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 662 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 7,123 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,955 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 658 07-05-2023, 03:57 AM
Last Post: paulcarton
Users browsing this thread: 7 Guest(s)
