Linux Support
#51
(11-03-2016, 04:45 AM)Ghelorn Wrote:
(11-02-2016, 11:53 AM)modsbyus Wrote:
(11-02-2016, 07:12 AM)Ghelorn Wrote: The version I downloaded yesterday is working pretty good. can't seem to find a good working virtual keyboard but its working after all
Sent from my Nexus 6P using Tapatalk
Have you tried Onboard?
sudo apt-get install onboard
I haven't finished compiling the img yet, so I haven't tried it.
Onboard fails to start and florence crashes when you press any key on it.
The only one I have been able to get to work just from repos is xvkbd.
this is the output for florence:
p { margin-bottom: 0.1in; line-height: 120%; }
Key 0x51ea00 (type 0): Event 0 received : Switching from state 1 to 1 (fsm 0)
sending press event
** (florence:4538): WARNING **: Error retrieving accessibility bus address: org.freedesktop.DBus.Error.ServiceUnknown: The name org.a11y.Bus was not provided by any .service files
** (florence:4538): ERROR **: AT-SPI: Couldn't connect to accessibility bus. Is at-spi-bus-launcher running?
Trace/breakpoint trap
sending press event
I don't know about florence but for onboard  install
sudo apt-get install gir1.2-atspi-2.0
Then go to onboard settings and in the general uncheck Auto-show when editing text . In keyboard uncheck enabled  under typing assistance. Onboard should start.
sending press event
You also need to install at-spi2-core if you don't have that already.
gir1.2-atspi-2.0 fixed issues with onboard
at-spi2-core fixed the issues with florence
I also noticed the brightnes on the lcd is lacking but can be turned up with the gpio pin. I just run a small scrip that sets the required pin to high and then sets it to low when it detects xscreensaver running.
(11-09-2016, 04:41 PM)Ghelorn Wrote: I also noticed the brightnes on the lcd is lacking but can be turned up with the gpio pin. I just run a small scrip that sets the required pin to high and then sets it to low when it detects xscreensaver running.
Which GPIO controls the brightness? Would you mind sharing your script?
this code is dirty but just checks the state of xscreensaver and writes to the pin. there are better ways but this works. needs root
doesnt actually turn off the lcd though. just dulls it.
echo 362 > /sys/class/gpio/export
echo out > /sys/class/gpio/gpio362/direction
while true; do
 case "`xscreensaver-command -time | egrep -o ' blanked|non-blanked|locked'`" in
   " blanked")     echo 1 > /sys/class/gpio/gpio362/value ;;
   "non-blanked")  echo 0 > /sys/class/gpio/gpio362/value ;;
 esac
 sleep 5
done
while true; do
 esac
 sleep 5
done
That works! (I just manually ran the 2 echo commands). I had no idea it could get so bright. Thanks!
Is there an image available for down-load anywhere ? My old hardware can't really run Ubuntu 16.04 64bit in a VM and it is only 2 core.
The script runs OK but hangs during kernel compilation.
When new technology rolls over, you are either part of the steam roller... or part of the road.
(11-30-2016, 03:46 AM)Jessica Spongekipper Wrote: Is there an image available for down-load anywhere ?  My old hardware can't really run Ubuntu 16.04 64bit in a VM and it is only 2 core.
You can download UbuntuDebianopenSUSE or Fedora (if you are OK with not using a GUI).
Donate BTC: 3Eav9uqXi8Nx1axb7QjK6xV4km4K9YGv9a
Compilation finished (after 325 minutes) on the fourth attempt. The resulting .img file however does not boot. I used the script on the Armbian page, left it at default except for BOARD="pine64" and KERNEL_ONLY="no"
Any hints or tips for a comparative newbie ?
I assumed that the only reason a quad core VM was specified was to cut down on processing time.
Information LCD Support on Linux pfeerick 8 19,528 02-08-2021, 03:30 PM
Last Post: HBeserra
  [EXPERIMENTAL] Linux on the LCD screen Terra854 24 36,015 07-21-2017, 07:41 AM
Last Post: apple4ever
  Touch screen support shariq_2001 14 20,342 12-07-2016, 07:47 AM
Last Post: Luke
Photo Playbox LCD on Linux MackPI 10 16,396 10-19-2016, 07:49 AM
Last Post: Zoidiano0
  Received a bad LCD, can't get support. bryanlyon 3 5,050 09-27-2016, 03:55 AM
Last Post: Luke
  Touchscreen support? NoahJ 12 15,978 07-09-2016, 12:01 PM
Last Post: yodermk
  LVDS support Flood_of_SYNs 2 6,631 12-22-2015, 05:08 PM
Last Post: balornt
