Pinephone battery issue
Bug
There is some weird battery issue with this pinecone. Battery level dropped from 88% to 26% in 5 minutes. Feeling the battery temperature with the left hand with the cover off and navigating apps on the phone ( reproduced both with Ubuntu touch and Postmarket OS ) I am feeling the battery getting very hot then dropping back to room temperature as I am navigating apps on the phone. When the battery gets hot, the battery indicator level is visually decrementing percentages as I am looking at the display.
Any other users experiencing this issue?
What model do you have? Braveheart, UBports or postmarketOS Community Edition?
The battery indicator, especially on Ubuntu Touch, is inaccurate. Regardless, the heat described is abnormal.
A couple of things to try:
If the heat issue persists, report back and consider contacting Support.
(09-04-2020, 10:37 AM)jed Wrote: What model do you have? Braveheart, UBports or postmarketOS Community Edition?
Hello. The phone is the UBPorts edition.
The same here with a PostmarketOS version.
Has you solved the problem?
Many thanks in advance.
T.
I have received the Postmarket OS convergence edition 2 weeks ago, and the same battery issue as described occurs,
the phone does not hold on the battery and discharge pretty quickly when using the phone
(meaning when the phone is not plugged to the charger).
@mactoni @Jyv Is the heat issue also manifesting, or just poor battery performance?
If you are experiencing a heat issue like the OP, I'd recommend contacting Support. Otherwise, know that the PinePhone's battery life is short compared to other smartphones.
  PinePhone Keyboard update [April 24/04] Luke 73 109,557 08-12-2022, 11:46 AM
Last Post: kat22
  The PinePhone keyboard and cases are here! Luke 11 10,619 03-11-2022, 07:16 AM
Last Post: nontrivial
  PinePhone community poll results Luke 2 3,859 02-01-2022, 04:03 PM
Last Post: zer0sig
  PinePhone Pro Explorer Edition is now available Luke 1 3,329 01-12-2022, 11:52 AM
Last Post: zer0sig
  PinePhone BE & Pinebook Pro shipping update thread Luke 136 169,134 06-04-2021, 09:43 AM
Last Post: Luke
  PinePhone Mobian CE shipping update thread Luke 59 81,983 04-25-2021, 12:57 PM
Last Post: Luke
  PinePhone BETA Edition pre-orders start March 24 Luke 2 6,146 04-23-2021, 09:25 PM
Last Post: ryo
  PinePhone KDE Community Edition shipping update thread. Luke 135 178,876 04-11-2021, 01:47 PM
Last Post: Luke
  Manjaro PinePhone Community Edition Luke 17 32,613 11-02-2020, 01:32 PM
Last Post: bcnaz
Information August/ September Pinebook Pro, PineTab and PinePhone shipping thread Luke 256 378,756 10-27-2020, 11:14 AM
Last Post: Luke
