Mobian stuck in bootloop
Hey all,
I flashed the 16/06 build (and later the nightly) on a 32GB SanDisk microSD card. Sadly, in both cases Mobian is stuck during the plymouth boot screen (circle keeps circling indefinitely).
PostmarketOS works with this card, so I guess the microSD is not the problem. UBports is on the internal flash.
Any clue what the problem might be? Thanks.
(06-25-2020, 04:04 AM)The_Bolder Wrote: Hey all,
Hi!,
Maybe you can try another version in case that build you used is not working fine.
Also it could be the SD card was not created properly, what is your method to create the write the image onto the SD?
I used dd and made sure the card was unmounted.
I dug through the issue tracker and found that, apparently, there is some kind of problem with partition checking during boot. So maybe that's what causes the bootloop.
Update: using JumpDrive to flash it on the internal mmc worked! No clue what's going on with the microSD cards....
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 16 2,007 6 minutes ago
Last Post: zetabeta
  Mobian repository status henrythemouse 16 8,750 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 132 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 1,995 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,824 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 633 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 6,899 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,901 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 631 07-05-2023, 03:57 AM
Last Post: paulcarton
  Has anyone got briar-desktop running on mobian? vusra 5 3,020 06-19-2023, 03:02 PM
Last Post: vusra
