Pinebook Pro/Pinetab replacement
(07-29-2021, 02:22 AM)as400 Wrote: Well, if I did my detective work properly, JingOS team uses BSP kernel (4.14.133-something). And probably also BSP u-boot. Which is not good.
Thought as much - I didn't dig into it as much as I guess you did, but nothing I found so far was suggesting mainline support even in the works, and therefore this device is a no-go for me as of right now.
(07-29-2021, 02:22 AM)as400 Wrote: They say, they have also Vulkan working and it is still in works. That would suggest that they are working on it. Not Unisoc. Maybe they will mainline the driver. Who knows.
I'll believe it when I see it. Until then - nah.
(07-29-2021, 02:22 AM)as400 Wrote: As to the hardware from China - almost everything nowadays is from China Smile Pinebook Pro, Pinetab and Pinephone too Smile
Oh I'm perfectly aware of that! Heck, recently I've become more reserved even about my beloved ThinkPads, which (unlike Pinebooks) come with manufacturer-provided firmware that I for the most part can do nothing about if it decides to take over the system using some ACPI hooks or hypervisor mode. My only hope there is that ThinkPads are intended to be enterprise-level business machines that at least in theory should have more stringent QA and certification processes, unlike consumer-grade machines. And with PB/PBP the "untouchable" firmware is limited to just the 32K bootrom (AFAIK - ignorance is bliss?), though at least in theory those 32K could be plenty to plug in something nasty. Still, the more software/firmware is under my control - the better I sleep.
This message was created with 100% recycled electrons
(07-29-2021, 02:50 PM)moonwalkers Wrote: Still, the more software/firmware is under my control - the better I sleep.
I'm 100% with you.
(07-29-2021, 02:50 PM)moonwalkers Wrote: And with PB/PBP the "untouchable" firmware is limited to just the 32K bootrom (AFAIK - ignorance is bliss?), though at least in theory those 32K could be plenty to plug in something nasty.
Well, not only. Actually, for instance, there is also firmware in wifi card, touchpad, keyboard, eDP, USB-C, charge controller. Which is anyway probably less than in any other, similar product on the market.
Whether this firmware is a viable attack surface is a debatable thing of course. And we'll probably never know for sure. Like with this modified chinese northbridge firmware that was loaded into many server motherboards.
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 4 1,097 05-06-2024, 09:27 AM
  Pinebook Pro on Debian 12 Power Issue u974615 1 470 03-13-2024, 10:46 AM
Last Post: u974615
  Bad replacement battery? chris88233 3 564 02-19-2024, 04:59 PM
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 414 02-17-2024, 07:06 PM
  Pinebook Pro charging issues tomekdev 1 747 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement main board for Developers mozes 10 2,163 11-27-2023, 04:14 AM
Last Post: mozes
  Replacement battery for PineBook Pro DrYak 3 1,295 11-07-2023, 10:09 AM
Last Post: DrYak
  Battery replacement mjc 2 3,000 09-26-2023, 01:08 AM
Last Post: david-lechner
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 133,982 09-13-2023, 03:43 AM
Last Post: k3dAR
  PineBook Pro dead ottahe 9 6,314 01-18-2023, 07:41 PM
Last Post: ottahe
