KDE Plasma Interface Scaling
I have my second pinephone now. It is the KDE Plasma Edition. I quite like the UI and it runs ok it seems. Only problem is, I am missing functionality like scale-to-fit that is available for phosh. I can't for example configure nextcloud client since buttons are missing on the UI. Is there something like scale-to-fit or wlr-randr for KDE Plasma?
Best Regards,
anhilde
(02-27-2021, 10:32 AM)anhilde Wrote: Hi,
Best Regards,
anhilde
Have you tried landscape mode?
Best Regards,
anhilde
Does not help. I have given up for now and returened to arch with phosh. There I get the main things working for a daily driver.
Best Regards,
anhilde
Was there a solution found for this?
Best Regards,
anhilde
I think it shouls work ok. My own nextcloud, owncube, displays all buttons. But of course, I'd like to connect my calendars soon, too. Also my map app, Pure Maps, displays very useable.
If you go to Settings > Display, there's a "Scale" slider. By default, I think it's 200%. You can tweak it.
Try to tweak the font size as well, because Plasma tends to adjust other graphical elements based on font size as well.
  what is wrong with KDE plasma beta15 RC4? Uturn 8 1,862 10-02-2023, 05:07 AM
Last Post: Uturn
Exclamation My short experience with Manjaro Plasma Mobile anonymous 10 5,183 03-02-2023, 07:25 PM
  Manjaro plasma-mobile Beta 13 Uturn 13 5,288 01-25-2023, 04:15 PM
  Manjaro Plasma busted Chief 2 1,672 11-22-2022, 05:00 PM
Last Post: Chief
  Disabling screen timeout for plasma mobile rp3 7 7,460 09-05-2022, 03:50 PM
Last Post: christev1
  VPN on Plasma Hobgoblin 1 1,360 08-29-2022, 03:14 AM
Last Post: saddamus
  manjaro-pinephone / plasma-mobile-dev: Update broken Uturn 32 30,408 07-28-2022, 12:40 PM
Last Post: johaennessen
  |Plasma] Blank screen + pointer, SDDM error tuxmain 0 1,044 07-04-2022, 11:42 AM
Last Post: tuxmain
  double tap to wake > plasma mobile Uturn 3 2,492 05-19-2022, 07:55 PM
Last Post: epiii2
  auto start waydroid in plasma mobile? Uturn 2 2,582 04-19-2022, 03:47 AM
Last Post: dorthatapia
