Upgraded to 3G/32G and will not boot if SD card inserted
I bought the UTce phone back in June and I upgraded recently to the 3G/32G mainboard.  I flashed the eMMC and it runs fine.  If I flash an SD card it will boot and run fine.  However, if I use the eMMC with a storage only SD card inserted then it gives me a red light and never boots.
My guess is that the phone sees the SD card, cannot see anything to boot, but then doesn't switch to the eMMC.  Is there a config I need to edit or some package I need to retrieve from the old mainboard?
https://forum.pine64.org/showthread.php?tid=10820
Wow, I thought I searched well for the fix then the "related threads" when I posted had the answer. Because I used that SD card previously (on my original mainboard) as bootable SD card it still had a remnant u-boot sector. This link gives the terminal command to fix it: https://forum.pine64.org/showthread.php?...1#pid42411.
I inserted the SD card to my laptop, used lsblk to confirm the device, then ran "sudo dd if=/dev/zero of=/dev/mmcblk0 bs=1024 seek=8 count=2048". Afterward I did need to reformat the SD card, so ensure you have a fresh backup available.
  Can't boot on SD anymore LeNouveau 1 548 02-12-2024, 01:05 PM
Last Post: LeNouveau
  Does Ubuntu modify a Pinephone SD boot card? Peter Gamma 0 1,031 10-05-2023, 09:18 AM
Last Post: Peter Gamma
  External SD card not listed by Pcmanfm? Peter Gamma 1 1,715 08-22-2023, 12:22 PM
  Tow-boot headaches. antiwesley 3 1,651 04-30-2023, 05:03 PM
  problem with boot evaldas 2 2,342 03-17-2023, 06:21 AM
Last Post: gulshan212
  Article: NuttX RTOS for PinePhone: Boot to LVGL lupyuen 2 1,981 01-23-2023, 10:41 PM
Last Post: lupyuen
  tow-boot shulamy 2 1,776 09-08-2022, 12:33 AM
Last Post: shulamy
  Device memory full on multi-boot SD card Peter Gamma 4 2,919 08-27-2022, 10:03 AM
Last Post: Eugo
  wiping u-boot off sd card shulamy 6 3,159 08-17-2022, 03:38 AM
Last Post: shulamy
  Change tow-boot boot order or otherwise make Mobian on uSD the default? allworlds 3 2,595 05-04-2022, 06:27 PM
Last Post: allworlds
