slarm64 (unofficial slackware) Pinebook Pro RK3399 (aarch64)
support for slarm64 for Pinebook Pro (aarch64 unofficial port slackware)
the system can be assembled as armhf and aarch64, assemblies are made under aarch64
links:
        site: fail.pp.ua
        forum: linuxquestions
shortly about the slarm64, a simple non-overloaded system for everyday and not just use.
after corrections build new images with a new kernel 5.7.6
slarm64-current-aarch64-base-rootfs-20200628-5.7.6-pinebook_pro-build-20200629.img.zst
slarm64-current-aarch64-base-rootfs-20200628-5.7.6-pinebook_pro-build-20200629.img.zst.md5
slarm64-current-aarch64-xfce-rootfs-20200628-5.7.6-pinebook_pro-build-20200629.img.zst
slarm64-current-aarch64-xfce-rootfs-20200628-5.7.6-pinebook_pro-build-20200629.img.zst.md5
donation   slarm64
update
README.TXT
slarm64-current-aarch64-base-rootfs-20201115-5.9.9-pinebook_pro-build-20201120.img.zst
slarm64-current-aarch64-base-rootfs-20201115-5.9.9-pinebook_pro-build-20201120.img.zst.sha256
slarm64-current-aarch64-xfce-rootfs-20201115-5.9.9-pinebook_pro-build-20201120.img.zst
slarm64-current-aarch64-xfce-rootfs-20201115-5.9.9-pinebook_pro-build-20201120.img.zst.sha256
donation   slarm64
I thought I should give this a try,, xfce
Locks on DM screen, both mouse and kb,, unable to get vt (kb locked?)
Needs repeated presses to start up (2x?)
(11-26-2020, 01:45 PM)wdt Wrote: I thought I should give this a try,, xfce
the first inclusion allocates space to the entire map and automatically reloads, the second loading expands the partition.
switching to the console by ctrl+alt+F1-F6, I can not check the screen lock, there is no given device, I will be grateful for checking and solving errors, thanks.
it is also possible that the function keys do not correspond to the keyboard.
donation   slarm64
Yes, I saw the first 2 boots, it actually did not automatically reboot (maybe I should have given more time?)
--later-- changed inittab ->3, login OK, vt switch OK, startx, kb and mouse locked
All I can do is hard power off, lsusb gives a different name for kb, same ID
(since kb is flashed with new firmware, could that be it? maybe I should try usb kb)
Also, still have to press pwr twice for it to start
usb kb should work.
yes, maybe because of the firmware try changing the identifier in /etc/X11/xorg.conf.d/40-pinebookpro-touchpad.conf
donation   slarm64
Yes, tried changing 40-pinebookpro-touchpad,,, same name as lsusb,
but made no difference (and there does exist /dev/input/event[0-9])
Xorg -configure errored out,,,, xorgconfigure failed to write anything
Didn't dig out usb kb yet
needed /var/log/Xorg.0.log
donation   slarm64
I hope this is not too big
[ 414.098]
X.Org X Server 1.20.9
X Protocol Version 11, Revision 0
[ 414.135] Build Operating System: Slackware 15.0 Slackware Linux Project
[ 414.152] Current Operating System: Linux pinebook-pro 5.9.9 #1 SMP Wed Nov 18 21:37:09 UTC 2020 aarch64
[ 414.153] Kernel command line: root=/dev/mmcblk1p1 ro rootwait rootfstype=ext4 init=/sbin/init console=ttyS2,1500000n8 console=tty1 consoleblank=0 loglevel=4 usb-storage.quirks= earlycon=uart8250,mmio32,0xff1a0000
[ 414.160] Build Date: 13 September 2020 06:34:23AM
[ 414.163]
[ 414.166] Current version of pixman: 0.40.0
[ 414.173] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 414.173] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 414.187] (==) Log file: "/var/log/Xorg.1.log", Time: Fri Nov 27 01:02:13 2020
[ 414.190] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 414.193] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 414.194] (==) No Layout section. Using the first Screen section.
[ 414.194] (==) No screen section available. Using defaults.
[ 414.194] (**) |-->Screen "Default Screen Section" (0)
[ 414.194] (**) | |-->Monitor "<default monitor>"
[ 414.194] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 414.194] (==) Automatically adding devices
[ 414.194] (==) Automatically enabling devices
[ 414.194] (==) Automatically adding GPU devices
[ 414.194] (==) Automatically binding GPU devices
[ 414.194] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 414.194] (WW) The directory "/usr/share/fonts/local" does not exist.
[ 414.194] Entry deleted from font path.
[ 414.194] (WW) The directory "/usr/share/fonts/CID" does not exist.
[ 414.194] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF,
/usr/share/fonts/OTF,
/usr/share/fonts/Type1,
/usr/share/fonts/75dpi/:unscaled,
/usr/share/fonts/100dpi/:unscaled,
/usr/share/fonts/75dpi,
/usr/share/fonts/100dpi,
/usr/share/fonts/cyrillic
[ 414.194] (==) ModulePath set to "/usr/lib64/xorg/modules"
[ 414.194] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 414.194] (II) Loader magic: 0x620c28
[ 414.194] (II) Module ABI versions:
[ 414.194] X.Org ANSI C Emulation: 0.4
[ 414.194] X.Org Video Driver: 24.1
[ 414.194] X.Org XInput driver : 24.1
[ 414.194] X.Org Server Extension : 10.0
[ 414.195] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 414.195] (II) Platform probe for /sys/devices/platform/display-subsystem/drm/card1
[ 414.233] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 414.233] (II) Platform probe for /sys/devices/platform/ff9a0000.gpu/drm/card0
[ 414.233] (II) no primary bus or device found
[ 414.234] falling back to /sys/devices/platform/display-subsystem/drm/card1
[ 414.234] (II) LoadModule: "glx"
[ 414.235] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
[ 414.241] (II) Module glx: vendor="X.Org Foundation"
[ 414.241] compiled for 1.20.9, module version = 1.0.0
[ 414.241] ABI class: X.Org Server Extension, version 10.0
[ 414.241] (==) Matched modesetting as autoconfigured driver 0
[ 414.241] (==) Matched fbdev as autoconfigured driver 1
[ 414.241] (==) Assigned the driver to the xf86ConfigLayout
[ 414.242] (II) LoadModule: "modesetting"
[ 414.242] (II) Loading /usr/lib64/xorg/modules/drivers/modesetting_drv.so
[ 414.243] (II) Module modesetting: vendor="X.Org Foundation"
[ 414.243] compiled for 1.20.9, module version = 1.20.9
[ 414.243] Module class: X.Org Video Driver
[ 414.243] ABI class: X.Org Video Driver, version 24.1
[ 414.243] (II) LoadModule: "fbdev"
[ 414.243] (II) Loading /usr/lib64/xorg/modules/drivers/fbdev_drv.so
[ 414.243] (II) Module fbdev: vendor="X.Org Foundation"
[ 414.244] compiled for 1.20.9, module version = 0.5.0
[ 414.244] Module class: X.Org Video Driver
[ 414.244] ABI class: X.Org Video Driver, version 24.1
[ 414.244] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 414.244] (II) FBDEV: driver for framebuffer: fbdev
[ 414.244] (--) using VT number 7
[ 414.299] (II) modeset(0): using drv /dev/dri/card1
[ 414.299] (WW) Falling back to old probe method for fbdev
[ 414.299] (II) Loading sub module "fbdevhw"
[ 414.299] (II) LoadModule: "fbdevhw"
[ 414.300] (II) Loading /usr/lib64/xorg/modules/libfbdevhw.so
[ 414.303] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 414.303] compiled for 1.20.9, module version = 0.0.2
[ 414.303] ABI class: X.Org Video Driver, version 24.1
[ 414.304] (II) modeset(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 414.304] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 414.304] (==) modeset(0): RGB weight 888
[ 414.304] (==) modeset(0): Default visual is TrueColor
[ 414.304] (II) Loading sub module "glamoregl"
[ 414.304] (II) LoadModule: "glamoregl"
[ 414.306] (II) Loading /usr/lib64/xorg/modules/libglamoregl.so
[ 414.335] (II) Module glamoregl: vendor="X.Org Foundation"
[ 414.335] compiled for 1.20.9, module version = 1.0.1
[ 414.335] ABI class: X.Org ANSI C Emulation, version 0.4
[ 414.349] (EE) modeset(0): eglInitialize() failed
[ 414.349] (EE) modeset(0): glamor initialization failed
[ 414.349] (II) modeset(0): ShadowFB: preferred NO, enabled NO
[ 414.349] (II) modeset(0): Output eDP-1 has no monitor section
[ 414.349] (II) modeset(0): Output DP-1 has no monitor section
[ 414.350] (II) modeset(0): EDID for output eDP-1
[ 414.350] (II) modeset(0): Printing probed modes for output eDP-1
[ 414.350] (II) modeset(0): Modeline "1920x1080"x60.0 148.50 1920 1968 2000 2200 1080 1083 1088 1125 (67.5 kHz eP)
[ 414.350] (II) modeset(0): EDID for output DP-1
[ 414.350] (II) modeset(0): Output eDP-1 connected
[ 414.350] (II) modeset(0): Output DP-1 disconnected
[ 414.350] (II) modeset(0): Using exact sizes for initial modes
[ 414.350] (II) modeset(0): Output eDP-1 using initial mode 1920x1080 +0+0
[ 414.350] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 414.350] (==) modeset(0): DPI set to (96, 96)
[ 414.350] (II) Loading sub module "fb"
[ 414.350] (II) LoadModule: "fb"
[ 414.350] (II) Loading /usr/lib64/xorg/modules/libfb.so
[ 414.355] (II) Module fb: vendor="X.Org Foundation"
[ 414.355] compiled for 1.20.9, module version = 1.0.0
[ 414.355] ABI class: X.Org ANSI C Emulation, version 0.4
[ 414.355] (II) UnloadModule: "fbdev"
[ 414.355] (II) Unloading fbdev
[ 414.355] (II) UnloadSubModule: "fbdevhw"
[ 414.355] (II) Unloading fbdevhw
[ 414.372] (==) modeset(0): Backing store enabled
[ 414.372] (==) modeset(0): Silken mouse enabled
[ 414.383] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 414.383] (==) modeset(0): DPMS enabled
[ 414.383] (II) Initializing extension Generic Event Extension
[ 414.383] (II) Initializing extension SHAPE
[ 414.383] (II) Initializing extension MIT-SHM
[ 414.383] (II) Initializing extension XInputExtension
[ 414.385] (II) Initializing extension XTEST
[ 414.385] (II) Initializing extension BIG-REQUESTS
[ 414.385] (II) Initializing extension SYNC
[ 414.385] (II) Initializing extension XKEYBOARD
[ 414.385] (II) Initializing extension XC-MISC
[ 414.385] (II) Initializing extension XFIXES
[ 414.385] (II) Initializing extension RENDER
[ 414.385] (II) Initializing extension RANDR
[ 414.385] (II) Initializing extension COMPOSITE
[ 414.385] (II) Initializing extension DAMAGE
[ 414.385] (II) Initializing extension MIT-SCREEN-SAVER
[ 414.385] (II) Initializing extension DOUBLE-BUFFER
[ 414.385] (II) Initializing extension RECORD
[ 414.385] (II) Initializing extension DPMS
[ 414.385] (II) Initializing extension Present
[ 414.385] (II) Initializing extension DRI3
[ 414.385] (II) Initializing extension X-Resource
[ 414.385] (II) Initializing extension XVideo
[ 414.385] (II) Initializing extension XVideo-MotionCompensation
[ 414.385] (II) Initializing extension GLX
[ 414.385] (II) AIGLX: Screen 0 is not DRI2 capable
[ 417.643] (II) IGLX: Loaded and initialized swrast
[ 417.643] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 417.643] (II) Initializing extension XFree86-VidModeExtension
[ 417.643] (II) Initializing extension XFree86-DGA
[ 417.643] (II) Initializing extension XFree86-DRI
[ 417.645] (II) Initializing extension DRI2
[ 417.647] (II) modeset(0): Damage tracking initialized
[ 417.647] (II) modeset(0): Setting screen physical size to 508 x 285
[ 418.277] (II) config/udev: Adding input device rockchip,es8316-codec Headphones (/dev/input/event8)
[ 418.278] (II) No input driver specified, ignoring this device.
[ 418.278] (II) This device may have been added with another device file.
[ 418.279] (II) config/udev: Adding input device Pine64 Pinebook Pro (/dev/input/event0)
[ 418.279] (**) Pine64 Pinebook Pro: Applying InputClass "evdev keyboard catchall"
[ 418.280] (**) Pine64 Pinebook Pro: Applying InputClass "libinput keyboard catchall"
[ 418.280] (**) Pine64 Pinebook Pro: Applying InputClass "keyboard-all"
[ 418.280] (II) LoadModule: "libinput"
[ 418.281] (II) Loading /usr/lib64/xorg/modules/input/libinput_drv.so
[ 418.293] (EE) Failed to load /usr/lib64/xorg/modules/input/libinput_drv.so: libwacom.so.2: cannot open shared object file: No such file or directory
[ 418.293] (EE) Failed to load module "libinput" (loader failed, 0)
[ 418.293] (EE) No input driver matching `libinput'
[ 418.293] (II) Falling back to input driver `libinput'
[ 418.293] (II) LoadModule: "libinput"
[ 418.294] (II) Loading /usr/lib64/xorg/modules/input/libinput_drv.so
[ 418.294] (EE) Failed to load /usr/lib64/xorg/modules/input/libinput_drv.so: libwacom.so.2: cannot open shared object file: No such file or directory
[ 418.294] (EE) Failed to load module "libinput" (loader failed, 0)
[ 418.295] (II) config/udev: Adding input device Pine64 Pinebook Pro Mouse (/dev/input/event2)
[ 418.295] (**) Pine64 Pinebook Pro Mouse: Applying InputClass "evdev pointer catchall"
[ 418.295] (**) Pine64 Pinebook Pro Mouse: Applying InputClass "libinput pointer catchall"
[ 418.295] (II) LoadModule: "libinput"
[ 418.295] (II) Loading /usr/lib64/xorg/modules/input/libinput_drv.so
[ 418.296] (EE) Failed to load /usr/lib64/xorg/modules/input/libinput_drv.so: libwacom.so.2: cannot open shared object file: No such file or directory
[ 418.296] (EE) Failed to load module "libinput" (loader failed, 0)
[ 418.296] (EE) No input driver matching `libinput'
[ 418.296] (II) Falling back to input driver `libinput'
[ 418.296] (II) LoadModule: "libinput"
[ 418.296] (II) Loading /usr/lib64/xorg/modules/input/libinput_drv.so
[ 418.297] (II) config/udev: Adding input device Pine64 Pinebook Pro Mouse (/dev/input/mouse0)
[ 418.297] (II) No input driver specified, ignoring this device.
[ 418.297] (II) This device may have been added with another device file.
[ 418.297] (II) config/udev: Adding input device Pine64 Pinebook Pro Touchpad (/dev/input/event3)
[ 418.297] (**) Pine64 Pinebook Pro Touchpad: Applying InputClass "evdev touchpad catchall"
[ 418.297] (**) Pine64 Pinebook Pro Touchpad: Applying InputClass "libinput touchpad catchall"
[ 418.297] (**) Pine64 Pinebook Pro Touchpad: Applying InputClass "libinput for Pine64 Pinebook Pro USB KEYBOARD Touchpad"
[ 418.297] (II) LoadModule: "libinput"
[ 418.298] (II) Loading /usr/lib64/xorg/modules/input/libinput_drv.so
[ 418.298] (EE) Failed to load /usr/lib64/xorg/modules/input/libinput_drv.so: libwacom.so.2: cannot open shared object file: No such file or directory
[ 418.298] (EE) Failed to load module "libinput" (loader failed, 0)
[ 418.298] (EE) No input driver matching `libinput'
[ 418.298] (II) Falling back to input driver `libinput'
[ 418.298] (II) LoadModule: "libinput"
[ 418.299] (EE) Failed to load /usr/lib64/xorg/modules/input/libinput_drv.so: libwacom.so.2: cannot open shared object file: No such file or directory
[ 418.299] (EE) Failed to load module "libinput" (loader failed, 0)
[ 418.299] (II) config/udev: Adding input device Pine64 Pinebook Pro Touchpad (/dev/input/mouse1)
[ 418.299] (II) No input driver specified, ignoring this device.
[ 418.299] (II) This device may have been added with another device file.
[ 418.300] (II) config/udev: Adding input device Pine64 Pinebook Pro System Control (/dev/input/event4)
[ 418.300] (**) Pine64 Pinebook Pro System Control: Applying InputClass "evdev keyboard catchall"
[ 418.300] (**) Pine64 Pinebook Pro System Control: Applying InputClass "libinput keyboard catchall"
[ 418.300] (**) Pine64 Pinebook Pro System Control: Applying InputClass "keyboard-all"
[ 418.300] (II) LoadModule: "libinput"
[ 418.300] (II) Loading /usr/lib64/xorg/modules/input/libinput_drv.so
[ 418.301] (EE) Failed to load /usr/lib64/xorg/modules/input/libinput_drv.so: libwacom.so.2: cannot open shared object file: No such file or directory
[ 418.301] (EE) Failed to load module "libinput" (loader failed, 0)
[ 418.301] (EE) No input driver matching `libinput'
[ 418.301] (II) Falling back to input driver `libinput'
[ 418.301] (II) LoadModule: "libinput"
[ 418.301] (II) Loading /usr/lib64/xorg/modules/input/libinput_drv.so
[ 418.302] (EE) Failed to load /usr/lib64/xorg/modules/input/libinput_drv.so: libwacom.so.2: cannot open shared object file: No such file or directory
[ 418.302] (EE) Failed to load module "libinput" (loader failed, 0)
[ 418.303] (II) config/udev: Adding input device Pine64 Pinebook Pro Consumer Control (/dev/input/event5)
[ 418.303] (**) Pine64 Pinebook Pro Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 418.303] (**) Pine64 Pinebook Pro Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 418.303] (**) Pine64 Pinebook Pro Consumer Control: Applying InputClass "keyboard-all"
[ 418.303] (II) LoadModule: "libinput"
[ 418.303] (II) Loading /usr/lib64/xorg/modules/input/libinput_drv.so
[ 418.304] (EE) Failed to load /usr/lib64/xorg/modules/input/libinput_drv.so: libwacom.so.2: cannot open shared object file: No such file or directory
[ 418.304] (EE) Failed to load module "libinput" (loader failed, 0)
[ 418.304] (EE) No input driver matching `libinput'
[ 418.304] (II) Falling back to input driver `libinput'
[ 418.304] (II) LoadModule: "libinput"
[ 418.304] (II) Loading /usr/lib64/xorg/modules/input/libinput_drv.so
[ 418.305] (II) config/udev: Adding input device Pine64 Pinebook Pro Wireless Radio Control (/dev/input/event9)
[ 418.305] (**) Pine64 Pinebook Pro Wireless Radio Control: Applying InputClass "evdev keyboard catchall"
[ 418.305] (**) Pine64 Pinebook Pro Wireless Radio Control: Applying InputClass "libinput keyboard catchall"
[ 418.305] (**) Pine64 Pinebook Pro Wireless Radio Control: Applying InputClass "keyboard-all"
[ 418.305] (II) LoadModule: "libinput"
[ 418.305] (II) Loading /usr/lib64/xorg/modules/input/libinput_drv.so
[ 418.306] (EE) Failed to load /usr/lib64/xorg/modules/input/libinput_drv.so: libwacom.so.2: cannot open shared object file: No such file or directory
[ 418.306] (EE) Failed to load module "libinput" (loader failed, 0)
[ 418.306] (EE) No input driver matching `libinput'
[ 418.306] (II) Falling back to input driver `libinput'
[ 418.306] (II) LoadModule: "libinput"
[ 418.306] (II) Loading /usr/lib64/xorg/modules/input/libinput_drv.so
[ 418.307] (EE) Failed to load /usr/lib64/xorg/modules/input/libinput_drv.so: libwacom.so.2: cannot open shared object file: No such file or directory
[ 418.307] (EE) Failed to load module "libinput" (loader failed, 0)
[ 418.307] (II) config/udev: Adding input device USB Camera: USB Camera (/dev/input/event1)
[ 418.307] (**) USB Camera: USB Camera: Applying InputClass "evdev keyboard catchall"
[ 418.307] (**) USB Camera: USB Camera: Applying InputClass "libinput keyboard catchall"
[ 418.307] (**) USB Camera: USB Camera: Applying InputClass "keyboard-all"
[ 418.307] (II) LoadModule: "libinput"
[ 418.308] (II) Loading /usr/lib64/xorg/modules/input/libinput_drv.so
[ 418.308] (EE) Failed to load /usr/lib64/xorg/modules/input/libinput_drv.so: libwacom.so.2: cannot open shared object file: No such file or directory
[ 418.308] (EE) Failed to load module "libinput" (loader failed, 0)
[ 418.308] (EE) No input driver matching `libinput'
[ 418.308] (II) Falling back to input driver `libinput'
[ 418.308] (II) LoadModule: "libinput"
[ 418.309] (EE) Failed to load /usr/lib64/xorg/modules/input/libinput_drv.so: libwacom.so.2: cannot open shared object file: No such file or directory
[ 418.309] (EE) Failed to load module "libinput" (loader failed, 0)
[ 418.310] (II) config/udev: Adding input device gpio-key-lid (/dev/input/event6)
[ 418.310] (II) No input driver specified, ignoring this device.
[ 418.310] (II) This device may have been added with another device file.
[ 418.310] (II) config/udev: Adding input device gpio-key-power (/dev/input/event7)
[ 418.310] (**) gpio-key-power: Applying InputClass "evdev keyboard catchall"
[ 418.310] (**) gpio-key-power: Applying InputClass "libinput keyboard catchall"
[ 418.310] (**) gpio-key-power: Applying InputClass "keyboard-all"
[ 418.310] (II) LoadModule: "libinput"
[ 418.311] (II) Loading /usr/lib64/xorg/modules/input/libinput_drv.so
[ 418.311] (EE) Failed to load /usr/lib64/xorg/modules/input/libinput_drv.so: libwacom.so.2: cannot open shared object file: No such file or directory
[ 418.311] (EE) Failed to load module "libinput" (loader failed, 0)
[ 418.311] (EE) No input driver matching `libinput'
[ 418.311] (II) Falling back to input driver `libinput'
[ 418.311] (II) LoadModule: "libinput"
[ 418.312] (II) Loading /usr/lib64/xorg/modules/input/libinput_drv.so
[ 418.312] (EE) Failed to load /usr/lib64/xorg/modules/input/libinput_drv.so: libwacom.so.2: cannot open shared object file: No such file or directory
[ 418.312] (EE) Failed to load module "libinput" (loader failed, 0)
aha, clearly missing x/libwacom
what image did you use?
corrected image for 20201120
donation   slarm64
  Slackware Linux working on PBP vxzero 0 168 06-05-2024, 04:30 PM
Last Post: vxzero
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 107 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 1,718 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 2,327 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,452 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,581 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 92,199 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 1,674 11-23-2023, 07:37 AM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,866 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,753 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
