PineTab Mobian
#41
FYI, audio on PineTab should be fixed with the latest update, an `apt upgrade` should bring you the latest improvements.
(09-15-2020, 11:16 PM)vmanis Wrote: If any folks from the Mobian project are reading this, I'd suggest adding a wiki page on installing and configuring window managers. postmarketOS offers Sway and Plasma Mobile, there may be other popular ones. (And yes, the page should say “at your own risk, we offer no support”.)
Actually none of us has experience of setting up another desktop since we're focusing on improving the phosh ecosystem, but feel free to contribute to the wiki, it's not moderated and registrations are open to anyone Smile
(09-16-2020, 02:40 AM)a-wai Wrote: FYI, audio on PineTab should be fixed with the latest update, an `apt upgrade` should bring you the latest improvements.
Sounds good...I'll want to get more experience with Mobian and Sway before attempting that. I'm really grateful for all the work you're doing!
@a-wai Thank you for your work on Mobian. I like it!
When it comes to overall performance, did you reach the end of the HW capability or is there a space for improvement? For example Firefox is usable but laggy.
(09-14-2020, 12:46 PM)vmanis Wrote: Has anyone succeeded in getting Sway running on Pinetab Mobian? So far, I've managed to get out of Phosh, by doing `systemctl disable phosh.service', and rebooting. That got me to a console prompt. I then installed Sway, and tried to run it, which resulted in the message `DRM universal planes unsupported'. I know nothing about Wayland, so I'm stuck. Any help would be appreciated.
I've made progress on Sway/Mobian. I thought that it might be a lack of Mesa (OpenGL) packages, so I installed as many as I could find.  Still no joy. Then for some reason I checked libwayland-egl1-mesa. After installing that, Sway started up very nicely. In portrait mode, alas. Fortunately, the wlr-randr command can fix that (wlr-randr --output DSI-1 --transform 270). I don't know what the minimal fix for Sway is, but this got me going.
You should be able to use a similar approach to install other window managers, as long as they support Wayland.
Would you mind writing a quick guide on getting sway going? I would really like to see a desktop environment on the tablet at the moment.
I haven't done enough with it yet to justify doing a guide. I hope by next week to have some more, and will post accordingly.
(09-16-2020, 06:44 PM)vmanis Wrote: I haven't done enough with it yet to justify doing a guide. I hope by next week to have some more, and will post accordingly.
Great. Thank you.
This morning I found out by accident that hitting the pine-button and an arrow during startup (I was trying to turn off the keyboard LED's), results in the entire boot process being displayed Smile
Since I have a habit of removing the options quiet and splash from the grub config on desktop installs, I like to see what's happening during startup, is there any way to make this permanent in Mobian?
Can - in phosh - the orientation "landscape" made sticky on reboot?
After sleep the orientation "landscape" is heads down and could only be restored with switching back to portrait and then to landscape again?
Another question: Is there any possibilty to enable "auto login" in phosh?
Missing functions:
- bluetooth adapter not recognized
Any workarounds or settings for this?
I second firefox-58's question, anybody know of a way to make landscape mode sticky after reboot?
This may be related, but I downloaded the most recent image, DD'd it to a micro SD card and booted to it. It is working fine, but how do I install it to the eMMC?
Perhaps the PMOS "Boot Strap Method" that is gaining popularity. ?
Fairly easy steps to follow.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
  PineTab 2 login screen rotation fix chzbacon 11 4,795 03-17-2024, 04:53 PM
Last Post: mtomaschett
  NixOS on PineTab 2 asonix 3 2,394 02-24-2024, 12:29 PM
Last Post: Evergreen
  [PineTab2] Issues with Mobian Networking Cornelia Xaos 7 3,056 12-30-2023, 10:02 PM
Last Post: Cornelia Xaos
  Mobian Boot Problem rogerwegmann 14 4,506 12-13-2023, 11:04 AM
Last Post: diederik
  Working OS on pinetab RISC-V? user641 3 1,060 12-13-2023, 08:11 AM
  Mobian won't boot after ton of updates bartgrefte 11 5,315 12-10-2023, 02:47 AM
Last Post: bartgrefte
  Pinetab 2 as Pinebook Pro replacement Corkonian 4 2,533 08-15-2023, 11:22 AM
Last Post: CadenAnderson
  Software for PineTab-V msm 12 5,144 08-05-2023, 05:08 PM
Last Post: bingch
  Mobian - Phosh frtodd 1 1,307 06-18-2023, 04:51 AM
Last Post: GloriousCoffee
  Arch Linux ARM on PineTab 1 Danct12 25 30,563 06-10-2023, 05:33 PM
Last Post: fxc
