Could you create an Android Laptop out of the Rock64
Pretty quick question, could I create my own "Pinebook" that is android based and uses the Rock64 single board computer.
- LongLogStudios
does the rock64 have a battery connector? could you create one by hacking through gpio or even the 5v power supply connector?
(12-24-2017, 09:40 AM)dkryder Wrote: does the rock64 have a battery connector? could you create one by hacking through gpio or even the 5v  power supply connector?
The ROCK64 doesn't have the battery connector. You can using the battery add-on HAT module that developed for Raspberry Pi and use in ROCK64 board.
I was thinking of trying the PiTop chassis with the rock64, but it turns out to be too expensive to import to my country for testing purposes. Has anyone else tried it?
(12-31-2017, 02:10 AM)CaptainZalo Wrote: I was thinking of trying the PiTop chassis with the rock64, but it turns out to be too expensive to import to my country for testing purposes. Has anyone else tried it?
I am interested in this as well; I have ordered and am waiting on the Pinebook, which I look forward too, and have also ordered a Pine-LTS and a Rock64, which if it would work properly, and I assume for the most part it should, would make an amazing replacement in the PiTop.
  Are HW design files available for ROCK64? irenek 3 5,266 12-11-2023, 09:31 PM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 0 395 11-23-2023, 05:05 AM
Last Post: ReleaseTheGeese
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 1,163 04-26-2023, 11:38 PM
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 0 669 03-21-2023, 03:48 PM
Last Post: o1CRiMSON1o
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 13,515 01-15-2023, 10:36 AM
Last Post: ds00
  rock64 totally brick dakobg 2 1,863 11-07-2022, 05:45 PM
Last Post: olivercfc
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 3,629 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 2,749 06-08-2022, 12:44 AM
Last Post: Zoz
Smile wooden case for ROCK64 killor 13 16,897 03-04-2022, 06:56 AM
Last Post: killor
  1wire DS18b20 on Rock64? mypineme 6 7,245 09-28-2021, 03:07 PM
Last Post: TRS-80
