Downsides of the open-source modem firmware?
I recently got myself a PinePhone and intend to use it as my everyday phone.
I learnt there is an alternative, open-source firmware available for the Quectel modem.
Are there any downsides of using it instead of the original firmware?
I read a lot about its benefits (improved security, lower operating temperature, etc.) but nothing about possible issues with it.
Is there something which is known to work better with the original firmware or am I basically loosing nothing by ditching it?
Thank you!
PinePhone Beta Edition 3GB RAM - custom firmware v.0.7.4 - ADSP v.30.007 - postmarketOS edge - sxmo
Yes, that would be interesting to know - I recently stumbled about the same question...
Stability/Reliability is king for me, lower temperature and stuff is gread, but only if stability/reliability is at least on the same level as with the stock firmware. Smile
Using encrypted Mobian (bookworm) on pmOS CE Convergence PinePhone (3GB/32GB) as Daily Driver, and Beta Edition Convergence PinePhone (3GB/32GB) with encrypted Mobian (bookworm) as Backup device.
(10-18-2022, 09:26 AM)alpineduck Wrote: Are there any downsides of using it instead of the original firmware?
I'm no expert, but I remember reading that using the free firmware would probably be illegal in most countries. Something about being able to change your hardware identification.
I don't claim to be 100% right, but I'm pretty sure of the below - please correct me if someone knows better Big Grin
Biktorgjs modem it not replacing the actual "modem black box" thing which is that "secret" and legally controlled technology. ADSP is still the same as in stock firmware and ADSP is the part which does the actual work of the modem, i.e. makes a connection to cell towers etc.
Biktorgjs modem replaces the userspace so it gives more control between the modem and the phone's own user interface.
I have several pinephos in daily use. I'm not a developer, but I'm an active tester and I can't figure out a single thing what was better in stock firmware.
But because worldwide carriers work differently, your experiences may be different from mine (even though I have tried with three different carriers)
(10-20-2022, 12:17 PM)CharlieGordon Wrote: I'm no expert, but I remember reading that using the free firmware would probably be illegal in most countries. Something about being able to change your hardware identification.
If you're talking about the IMEI identification string, that can be can be changed in the stock firmware. It's been discussed on the board a fair amount if you search for it.
I've been wondering about the open source firmware as well, but the stock "002" firmware has been working well enough that I have not been motivated to try changing it.
  Article: NuttX RTOS for PinePhone: 4G LTE Modem lupyuen 2 1,648 04-10-2023, 10:19 PM
Last Post: lupyuen
Sad Modem is always visible/connected but stops working after a while dante404 6 3,271 11-08-2022, 09:12 AM
Last Post: dante404
  Latest firmware for PinePhone modem! Subsentient 104 132,143 07-20-2022, 05:32 AM
Last Post: zetabeta
  Beta support: MMS on chatty/mmsd on Modem Manager - help/testing wanted! kop316 201 190,546 03-24-2022, 03:16 AM
Last Post: as365n4
  What is the best firmware to use an external screen with? Scary Guy 4 3,335 02-16-2022, 01:36 PM
Last Post: Avisando
  Problem Flashing the modem Firmware loreson 0 1,203 12-22-2021, 10:31 AM
Last Post: loreson
  Solutions to modem / connection problems Anna 3 3,070 12-10-2021, 01:42 AM
Last Post: AntonReiser
  Open Source self hosted contact list? KNERD 13 10,036 11-27-2021, 12:46 PM
Last Post: KNERD
  Adafruit Pyloton Open Source Bike computer on the PinePhone? Peter Gamma 0 1,727 04-02-2021, 06:37 PM
Last Post: Peter Gamma
  Python3 Bridge SMS/MMS to Matrix using Modem Manager and MMSD FutureBucket 3 4,158 02-10-2021, 08:09 PM
Last Post: kop316
