Battery not charging when run down to 0.
Question
Having problem with PPPro battery.  After running down to 0 it will not take a charge,  I have to switch out a battery from from one of my PPs which has a charge and then it will boot. I place the PPPro battery in to the PP I switched battery from and it takes a charge and boots the PP and continues charging.  Don't know if the OS (Manjaro) or the battery is at fault. I suspect the OS. Would be nice to turn the Phone off when it reaches a certain threshold (5% maybe).
Found This:
General Discussion of PinePhone Pro › Guide to power off the Pinephone Pro on low battery. Addresses Turning off PPP at 5% threshold.
I found it necessary to switch off the phone modem to allow charging while powered up.
I also switched off the cameras since they do not work.
The cable with extended ends is necessary for charging.
  USB charging is unreliable lightwo 0 242 05-17-2024, 04:29 AM
Last Post: lightwo
  PinePhonePro turns on when connecting usb charging cable xt0 5 1,242 10-10-2023, 12:01 PM
Last Post: zetabeta
Sad PPP shuts off when reaching battery level >50% <70% crt0mega 5 1,935 09-06-2023, 08:36 AM
Last Post: crt0mega
  [Mobian] : Battery consumption and driver/middleware compatibility freelectro 1 802 05-30-2023, 03:27 AM
  Custom Battery Design questions. tenzen 1 1,016 04-26-2023, 11:00 PM
  New out of box phone, vibrates and solid red light on charging StuckInTheCloud 1 993 03-24-2023, 03:12 PM
Last Post: fxc
  Question on the keyboard battery with phone knoxvilles_joker 0 1,107 08-27-2022, 12:04 AM
Last Post: knoxvilles_joker
  J7 battery Frost1776 6 4,865 03-09-2022, 03:09 PM
Last Post: tckosvic
  charging indicator nristen 16 9,811 02-03-2022, 04:36 PM
Last Post: phelion
  USB to PC connection not charging PPP tckosvic 0 931 02-01-2022, 05:40 PM
Last Post: tckosvic
