PPP shuts off when reaching battery level >50% <70%
Sad
Hi there,
has someone else experienced such weird behaviour?
I couldn't use my PinePhone Pro for months now because the reported battery level immediately crashes to 0% at some point between 50% and 70%, leading to a forced shutdown. Support says it has to be a software problem but I actually doubt that. The battery itself is working flawlessly in another phone and the issue persists even if I boot up the factory test build.
Any help leading to fix this issue (besides buying a new mainboard) is appreciated.
Thanks Smile
You could replace the battery with a compatible one for relatively cheap if that's the cause (see https://wiki.pine64.org/wiki/PinePhone#Battery), especially if the issue persists across multiple distributions. If it turns out to be not caused by the battery you could still return it to the seller.
(06-16-2023, 12:23 PM)fxc Wrote: You could replace the battery with a compatible one for relatively cheap if that's the cause (see https://wiki.pine64.org/wiki/PinePhone#Battery), especially if the issue persists across multiple distributions. If it turns out to be not caused by the battery you could still return it to the seller.
Thanks, but the battery isn't damaged. It's working fine in my non-pro PinePhone. With the non-pro PinePhone battery in the PinePhone Pro on the other hand, the issue still remains.
Sorry, I missed the sentence about testing it in a regular PinePhone. It's the first time I heard about such an issue and it's quite tricky. We discussed it a bit in the community chat in the PinePhone channel, there might be some further information required. Would recommend you to join the chat channel: https://wiki.pine64.org/wiki/Main_Page#C...nd_Support (discussion starting at https://discord.com/channels/46323792798...0768905369).
(06-20-2023, 02:23 PM)fxc Wrote: Sorry, I missed the sentence about testing it in a regular PinePhone. It's the first time I heard about such an issue and it's quite tricky. We discussed it a bit in the community chat in the PinePhone channel, there might be some further information required. Would recommend you to join the chat channel: https://wiki.pine64.org/wiki/Main_Page#C...nd_Support (discussion starting at https://discord.com/channels/46323792798...0768905369).
Thank you, I'll try to join the discord discussion tomorrow – it's a bit late here now and I need to catch some sleep Wink
Edit: I've added a screenshot of my support ticket (hopefully without any personal data):
Spoiler:
I gave up and bought a new PPP mainboard. It looks like it's been shipped without SPI flash, so I'm facing the next couple of issues – yay xD A couple of reboots later, /dev/mtdblock0 showed up without errors.
  [Mobian] : Battery consumption and driver/middleware compatibility freelectro 1 730 05-30-2023, 03:27 AM
  Custom Battery Design questions. tenzen 1 929 04-26-2023, 11:00 PM
  Question on the keyboard battery with phone knoxvilles_joker 0 1,062 08-27-2022, 12:04 AM
Last Post: knoxvilles_joker
  J7 battery Frost1776 6 4,664 03-09-2022, 03:09 PM
Last Post: tckosvic
Question Battery not charging when run down to 0. iwm 2 1,884 02-08-2022, 10:45 AM
Last Post: mburns
  Battery discharge problem g4mba5 16 8,635 02-01-2022, 03:30 AM
Last Post: bcnaz
