J7 battery
I put a j7 battery in my PPP it fits but tightly, it's a 3000 just like the stock one. My question is being a little and a different should be good to run right.
It definitely holds a charge longer.
I had one replacement battery that was too tight, I filed the tight edge a little and now it fits just snug, -> perfect.
( the edge opposite the contacts)
I did not want an over tight battery to distort the internal components ...
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
(02-07-2022, 09:53 PM)bcnaz Wrote: I had one replacement battery that was too tight,    I filed the tight edge a little and now it fits just snug,  -> perfect.
I'll look at it and try that probably.
I tried this battery and it was about 1mm too long. https://www.ebay.com/itm/182514636954
Before I grow my collection of batteries, has anyone found a battery that fits?
(03-07-2022, 10:03 AM)thomzane Wrote: I tried this battery and it was about 1mm too long.  https://www.ebay.com/itm/182514636954
I have had pretty good results using the part number EB-BJ700CBE
I have bought 3 batteries from 2 different Ebay vendors, both are branded as Samsung, but from the first vendor,
whom I got 2 of these batteries, there is a watermark on his batteries,  but he ran out of stock last year.
I did find I had to file just a little from the lower edge of one battery, it was just a little too tight.
It would go in to the phone, but it was extremely hard to remove.
I don't think one was a different size,  more likely just a bit lax in their tolerances.
and
Filing a little bit off is not a big deal.
So far they all seem to be close in performance to the original Pine batteries.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
I got my cheap ebay battery to work! I did not feel comfortable shaving my battery, but I noticed that the bottom piece is likely glued on and I was correct. I was able to pry the bottom piece opposite the connections using a razor blade. I peeled the glue off after that. Now the battery is snug, but I can remove it without tools by turning it upside-down and lightly shaking the phone.
(03-09-2022, 02:07 PM)thomzane Wrote: I got my cheap ebay battery to work!  I did not feel comfortable shaving my battery, but I noticed that the bottom piece is likely glued on and I was correct.  I was able to pry the bottom piece opposite the connections using a razor blade.  I peeled the glue off after that.  Now the battery is snug, but I can remove it without tools by turning it upside-down and lightly shaking the phone.
Your battery from the PP fits fine into PPP.  Has same rating but says just PP on label. Sometimes I charge battery in PP where charging works fine and put it into PPP to tinker with software.
Sad PPP shuts off when reaching battery level >50% <70% crt0mega 5 1,799 09-06-2023, 08:36 AM
Last Post: crt0mega
  [Mobian] : Battery consumption and driver/middleware compatibility freelectro 1 743 05-30-2023, 03:27 AM
  Custom Battery Design questions. tenzen 1 944 04-26-2023, 11:00 PM
  Question on the keyboard battery with phone knoxvilles_joker 0 1,074 08-27-2022, 12:04 AM
Last Post: knoxvilles_joker
Question Battery not charging when run down to 0. iwm 2 1,903 02-08-2022, 10:45 AM
Last Post: mburns
  Battery discharge problem g4mba5 16 8,738 02-01-2022, 03:30 AM
Last Post: bcnaz
