Mobian kernel upgrade
Is mobian updating the 5.10 kernel with new patches or do we need to update/upgrade manually?
I have a bookworm install
There is information on upgrading to kernel 5.13 in the bookworm thread. (You'll want to be on the bookworm release if not already there. EDIT: I see you've already done that!) Installing the kernel amounts to:
apt search linux-image | grep sunxi  # List available kernels
apt install linux-image-5.13-sunxi64  # Install kernel
A wrinkle to this is that apparently with this kernel the screen brightness will be set to zero unless you otherwise set it during boot, so you'll want to do that first and make sure it's working before booting the 5.13 kernel. (Also to be on the safe side in case you get a black screen make sure you have another means of getting into the phone like ssh enabled.)
To set brightness at boot time I enabled the old-school /etc/rc.local file:
https://www.troublenow.org/752/debian-10-add-rc-local/
Then in /etc/rc.local I put the following command (higher number is more brightness and vice versa, I don't know what the max is):
echo 600 > /sys/class/backlight/backlight/brightness
(11-10-2021, 03:23 AM)user641 Wrote: Is mobian updating the 5.10 kernel with new patches or do we need to update/upgrade manually?
Looks to me that the latest 5.10 via update/upgrade is 5.10.56. (You can also install 5.14.8 via apt install.)
I think kernel 5.15 will probably come soon in Mobian. I would from my side wait until it's there as it's a long term supported one
(11-10-2021, 09:18 AM)vongillus Wrote: I think kernel 5.15 will probably come soon in Mobian. I would from my side wait until it's there as it's a long term supported one
I think this is the best approach for me, as I use as daily drive. Just checked I am running 5.10.56.
  Mobian-Kicksecure? 3460p 0 180 05-26-2024, 02:09 PM
Last Post: 3460p
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 27 3,421 05-17-2024, 07:58 AM
Last Post: treebeard
  atinout binaries for mobian/debian? NeutralGrey 2 279 05-13-2024, 02:42 PM
Last Post: Gumur
  Mobian repository status henrythemouse 16 9,426 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 283 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,393 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,969 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 735 09-01-2023, 11:29 AM
Last Post: Mahgue
Big Grin An early xmas present: 6.1 kernel treebeard 28 10,750 07-18-2023, 03:14 AM
Last Post: gischpelino
  how to update mobian over tor vusra 13 7,392 07-09-2023, 08:57 PM
Last Post: vusra
