Setting up Mullvad to run on Mobian
I have tried setting up Mullvad to run through OpenVPN (exactly how the site tells you to set up the VPN through OpenVPN in a terminal on Debian), and while nothing obviously goes wrong and my openvpn files seem to be in the right place, when I try to run sudo service openvpn start, nothing happens. Similarly nothing happens with the other command on Mullvad's website. I can't seem to import any sort of .ovpn or .conf file to the built in networking manager (it throws an unknown error), and any info I can find online about this is irrelevant, dead or unhelpful. Any help would be appreciated.
Use wireguard instead, it's better. sudo apt-get install wireguard-tools, unpack the mullvad-generated wireguard .zip file in /etc/wireguard, sudo ls /etc/wireguard | shuf -n1 to pick a random node, wg-quick up mullvad-<...>.conf
(11-06-2021, 05:12 PM)Dendrocalamus64 Wrote: Use wireguard instead, it's better.  sudo apt-get install wireguard-tools, unpack the mullvad-generated wireguard .zip file in /etc/wireguard, sudo ls /etc/wireguard | shuf -n1 to pick a random node, wg-quick up mullvad-<...>.conf
Just adding I had to install resolvconf as it was not available on fresh Mobian install. Also wg-quick command required only the connection name without .conf
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 27 2,984 05-17-2024, 07:58 AM
Last Post: treebeard
  atinout binaries for mobian/debian? NeutralGrey 2 153 05-13-2024, 02:42 PM
Last Post: Gumur
  Mobian repository status henrythemouse 16 9,217 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 190 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,191 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,917 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 674 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 7,239 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,974 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 669 07-05-2023, 03:57 AM
Last Post: paulcarton
