Announcing the Mobian project
Just Wondering :
Will the new "Convergence Package" have any effect on the 'Mobian' Project ?
Just curious, BC
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
(07-15-2020, 02:19 PM)dukla2000 Wrote: Seem to be 2 recent regressions:
1) Screen keeps waking up when on battery. Pretty sure this dates from the 5.7 kernel update, it was previously fixed.
2) Mobile data connection is lost when there is some power save (on battery) and cannot be recovered any obvious way other than a reboot. Seems to date about from when the new little status icon for no data connection appeared.
Both were a problem with my old nightly that was upgraded daily. And both still a problem with fresh install of 14 07 nightly.
The second issue has always been there actually: mobile data coming back up after waking up from sleep is fully random, sometimes it works, sometimes it doesn't, and it's still a bit mysterious (see this issue).
The first issue has been fixed previously, but it's now back under a different form. I seems to be tied to the modem issue this time, but I might have a workaround for this one, it maybe fixed this week.
After todays update Phosh seems snappier on Mobian. Or is that just me? Smile
Thanks to Crust, the battery life of the Pinephone is already relatively long and there seems to be a lot of room for improvement. In addition, I wonder if it is realistic to achieve an improvement in the battery life. Will it be possible to use the Pinephone longer and longer for web surfing, etc. or are we already at the limit? If not at the limit: What does it take to improve usage duration of the Pinephone?
Thanks again.
I thought I could pin down issue 2 - or more specifically avoid it - by waiting after pushing the power button for the network to recover BEFORE scrolling up and entering my PIN. At first it did seem to improve things but it certainly is not a 100% avoidance.
On my Brave Heart phone, running nightly builds, I no longer receive text ?
Noticed that on a recent build so I updated to July 20 nightly, and I still cannot receive or open the text app.
Anyone else ?
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
An update to purple-mm-sms was just pushed. Can you update and try again (reboot to be sure)?
If it does not help, maybe check with the advice in this thread.
Hope it helps!
(07-21-2020, 01:55 AM)devrtz Wrote: An update to purple-mm-sms was just pushed. Can you update and try again (reboot to be sure)?
Hope it helps!
I tried to run update through the GUI and it just returns to the previous screen after a few minutes of looking for updates.
I am downloading the July 21 nightly at the moment,  I hope to see some better results.
> ?  >  I have heard some mention of the modem being 'corrupted' by the phone being turned on and the battery being removed.  ?
While I do always turn off the phone before removing the back cover,  there has been a few times the phone accidentally got turned on while
I was removing the cover and the battery...
Hopefully  I have not corrupted the modem ?   it still works for incoming and outgoing calls.
Thank you for your help and suggestions,   BC
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
Update :
  Flashed the July 21 nightly to sd card and still no SMS text on my Brave Heart phone.
                                Cry
(07-21-2020, 02:34 PM)bcnaz Wrote: > ?  >  I have heard some mention of the modem being 'corrupted' by the phone being turned on and the battery being removed.  ?
While unlikely, it is possible to kill your modem when interrupting electricity. If you can still make calls, it should be fine though....
(07-21-2020, 09:36 PM)bcnaz Wrote: Update :
                                Cry
   (July 22 )
I did newest update :
      Now the text icon in the contact book is gone,    only shows the phone handset icon ?
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 21 2,170 10 hours ago
Last Post: anonymous
  Mobian repository status henrythemouse 16 8,831 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 140 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,022 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,843 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 643 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 6,948 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,913 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 639 07-05-2023, 03:57 AM
Last Post: paulcarton
  Has anyone got briar-desktop running on mobian? vusra 5 3,046 06-19-2023, 03:02 PM
Last Post: vusra
