04-03-2020, 02:49 PM
How do you enable GPS?
04-09-2020, 05:32 AM
(04-03-2020, 02:49 PM)supermagic Wrote: GPS was working fine before but it stopped working in #271 Hey I am currently working on it following this hint in the gps Issue on Github https://gitlab.com/ubports/community-por.../issues/50 My current state is the following * EG25 devices show up under /dev/ with udev rule as in pmOS patch https://github.com/jmechnich/qtposition_gpsd (just put it in /etc/udev rules.d) * gpsd can be installed and started with init.d script (see pmOS patch) * atinout 0.9.1 patched with https://github.com/beralt/atinout/commit...ea7df5bbb3 and cross compiled * device hook script installed and executes fin * Can see output after activation using cat /dev/EG25.NMEA * gpsd does not seen to work yet using gpsmon does connect but no gps position is shown Next steps * figure out whats wrong with gpsd any hints appreciated * cross compile https://github.com/jmechnich/qtposition_gpsd * figure out where qt plugins are located in UBports * make plugin work
07-22-2020, 07:36 AM
If you want to enable GPS now, you can go to https://forum.pine64.org/showthread.php?tid=10165, where it says how to enable it.
07-22-2020, 10:24 AM
(07-22-2020, 07:36 AM)RandomN00B Wrote: If you want to enable GPS now, you can go to https://forum.pine64.org/showthread.php?tid=10165, where it says how to enable it. For me it does NOT work! No GPS data after all these things listed and done in the thread listed above. I hope that on on any future build the GPS function will be happen
07-27-2020, 11:39 PM
(07-22-2020, 10:24 AM)firefox-58 Wrote:Didnt work for me at first either. Then i realized that i both had typos and was entering some script out of order. Then it worked fine. But it only seemed to stay on until i first switched the toggle off. Toggle back didnt seem to turn it back on. Bit of a pain if we must manually do this each time for now. Nonetheless, im seeing most growing pains worked out.(07-22-2020, 07:36 AM)RandomN00B Wrote: If you want to enable GPS now, you can go to https://forum.pine64.org/showthread.php?tid=10165, where it says how to enable it. |
| How to enable Ethernet with UBPorts and convergence dock? | piney-tim | 1 | 5,323 |
11-27-2020, 07:40 PM Last Post: piney-tim |
| How to enable SSH on UBPorts Ubuntu Touch? | eaglecup | 12 | 34,060 |
09-15-2020, 03:42 PM Last Post: voidmain |
