03-06-2020, 07:42 AM
I bought a USB hub and experienced similar issues as DrYak in https://forum.pine64.org/showthread.php?...4#pid54364
In one direction, I see 4 times USB 2.0
When I turn it 180 degrees, I get the full 3 times USB3.0 and rt8153 ethernet
I also used to have the problem that the ethernet adapter would disconnect, then reconnect every five minutes, but that issue seems gone now (I didn't do anything about it though)
Can this issue be fixed in the device tree maybe, or is the hardware faulty? For now, i just labeled my USB-C cable.
